rear wheel bearing job w pics
  • kmsnsx
    • May 2007
    • 63
    that tool set looks EXACTLY like the one I bought from harbor freight for $80
    • gazellebeigem3
      • Jun 2005
      • 3712
      Its from Baum and has a couple more pieces that i didnt bring. Dont get me wrong, i <3 harbor freight, but their set wouldnt be functioning at this point. I figure thats seen at least 100 wheel bearings and still works great.
      • ThaiRacer
        • 799
        what kinda tape did u use to fix you cv boots? I need a temp fix for mine to lol.
        • kmsnsx
          • May 2007
          • 63
          I don't doubt that the Baum or Pelican parts kit is of higher quality, but I'm just saying if you are like most people and you only need the tool twice, get the harbor freight one and if it breaks, return it.
          • red325i
            • 137
            HOLY PITA! So ive got the Halfshaft and the hub out (after i bought a bigger hammer)..now im pressing the bearing out with the bearing set from Harbor Freight ($69.99 -20%!!!!)...and holy PITA it is a slow process turning the bolt to press the bearing out...
            I cant imagine doing this any other way though...trying to pound the bearing out with a pipe or something.. no way.
            • red325i
              • 137
              EPIC Fail....Read the thread 100x's....was re-installing the hub and used a back plate that was the size of the outer race vrs the inner race..yep you guessed it pushed the bearing apart!
              Rookie mistake, attention to detail lacking..yep lets hear it..
              • dr.gonzo
                • Nov 2009
                • 206
                I am not looking forward to doing this. Thanks for the write up though
                www.roadreview.net
                • nicky51
                  • Jan 2010
                  • 158
                  Inquiry
                  Hey guys, just a quick question. The rear wheel bearings are gone when you hear that whining noise from the rear when your driving? Even when you push in the clutch it still whines and gets louder the faster you go. Thanks..
                  • DRTSRFR
                    • May 2008
                    • 1836
                    Anybody got a link to the Harbor Freight piece??
                    Suspension tips here...
                    http://www.r3vlimited.com/board/album.php?albumid=757
                    • FetusGoulash
                      • Apr 2009
                      • 91
                      That sounds like the diff is worn. wheel bearings make a whum whum whum whum type of sound and the frequency will change with speed.
                      • FredK
                        • 14763
                        My first wheel bearing job, this is exactly what I did. Well, second time was a charm. LOL.
                        • atan88
                          • Apr 2007
                          • 308
                          Very useful info. Thanks
                          • e30Matt
                            • 5077
                            Just did my bearing with the Harbor Freight kit. +1 for it, did it like a champ. I used an Ingersoll 1/2" drive impact gun to speed things up, took about an hour with me bullshitting around whilst doing it. Not afraid of rear wheel bearings anymore!
                            • alpinewhite318i
                              • 134
                              Anyone use this type of tool to install the halfshaft splines back into the hub? The tool is in the following link:
                              Free Shipping - OTC Ford Front Hub Installers with qualifying orders of $109. Shop Front Hub Assembly Installers and Pullers at Summit Racing.
                              • e30Matt
                                • 5077
                                Mine slipped in about 1/4 way, then I just rotated the shaft and hub and tapped on the backside of the joint body to seat it the rest of the way.
