Motronic or WAR?
  • LowR3V'in
    • 4209
    "You are ONLY missing out on...."
    Not even close.
    You're missing out on 1,000,000 things.
    • downforce22
      • Aug 2009
      • 3192
      I have researched from kamotors and others that first gear, before boost build, bogs down due to a rich condition. I don't understand how MS would do a better job of this vs war, shouldn't it have the same problem?
      • Northern
        I like cupcakes & sh!tboxes
        • 5248
        I've seen enough people get fed up with the WAR chip and switch to MS that I feel MS is the way to go.
        Originally posted by priapism
        Originally posted by shameson
          • 34844
          No. MS was designed for boost, and the technology is about 20 years newer.
          • kamotors
            • Nov 2007
            • 7102
            MS runs speed density, it "KNOWS" how much air is in the system. It will only send in the correct amount of fuel for the load and air in the motor unlike the WAR chip which just says, hey your at 4krpm lets send in a poo ton of fuel even though you cant reach boost in first gear..
            MS runs PERFECT on a boosted E30, never has stupid bogs or stutters ever, even if you blow a coupler the car will run, just simply be down on power.
            7speedshop.com
            • kamotors
              • Nov 2007
              • 7102
              Originally posted by sayed ali
              You will have major problems running 42lb injectors with war chip, as it's designed for 30lb max, with your motronic it's very difficult to have a custom chip to be able to run the 42lb injectors, but it's possible .. ;)
              Don't waste your time & money on war chip, stay with the stock motronic for your low boost or go with MEGASQUIRT for whatever boost, whatever injectors :)
              also that's not true...you can run 42lbers just fine on war chip as soon as you adjust the fueling for them. Friend is actually running 42lbers N/A and its runs just like stock.
              7speedshop.com
              • sayed ali
                • 762
                ^ When you were using WAR chip why didn't use the 42lbs then? I remember you have asked if its possible or not, and said most people who run 42lb have had problems..
                M20B28 Turbo
                My Build Thread
                http://www.r3vlimited.com/board/showthread.php?t=255839
                • sayed ali
                  • 762
                  Anyway, it's mentioned in their website, maybe it's a new software ..
                  https://www.millerperformancecars.co...category_id=10
                  M20B28 Turbo
                  My Build Thread
                    • 34844
                    he was turbo, it had issues in 1st gear no matter what he tried. N/A is a different story but I don't know what use 42# injectors are on an N/A motor.
                    link is broken
                    • kamotors
                      • Nov 2007
                      • 7102
                      link is broken
                      exactly boosted on war brings a whole new list of issues. The car using the 42lbers was going to supercharge but ran into issue and is currently DDing the car N/A with no issues.
                      7speedshop.com
