Squirley Coolant temp
  • Nitro Nick
    • Jan 2014
    • 268
    Hey Guys,
    Got a questions regarding my coolant temp.
    I'm running MS2pnp
    So my temp gauge on my gauge cluster works just fine. The gauge on the megasquirt works just fine as well during start up and beginning of driving. Once it warms up and during driving the coolant temp drops down to like 70 or 80 Degrees F. Can anyone comment on this or let me know if this has happened to them before. I was maybe thinking of a faulty sensor? The gauge on my cluster stays fine and hangs right around the midpoint where it should. Any related info would be helpful
    Thanks,
  • EatsHondas
    • Sep 2012
    • 404
    Did you tell the MS which coolant temp sensor you are using? There should specifically be a Bosch E30 option, or something very similar. There is a calibration curve for every sensor and if it's not set properly it can mess with your readings. If it's working in the dash, it's definitely an MS config problem.
    In Tuner Studio, top left corner:
    "Tools" > "Calibrate Thermistor Tables"
    1989 325i Lachssilber Sedan
    5-Speed Swapped
    M30B35 Swapped
    MegaSquirt MS3X
    1987 325i Lachssilber Sedan
    260k OEM Automatic Daily Baby
    • CorvallisBMW
      Long Schlong Longhammer
      • 13039
      ^yup, what he said
      • Nitro Nick
        • Jan 2014
        • 268
        Been MIA for a bit. I will check this out. I definitely did not know about that setting and will try it out later. Thanks!
        • Nitro Nick
          • Jan 2014
          • 268
          Could you screen shot me your calibration curve? I cant seem to figure it out.
          • keyland
            • Apr 2009
            • 67
            Lifted from the DIYautotune site... I use these values with no problems.
            It's been a couple years, but IIRC, there's a common sensors dropdown where you can select BMW 325 or something like that and it will prepopulate the curve with these same values.
            For the CLT, use the following table with a bias resistor setting of 2490 ohms:
            Code:
            Temperature F / C     Resistance In Ohms
            14 / -10                  9500
            68 / 20                   2500
            176 / 80                  330
            Enter these values, and click ‘Write to Controller’.
            Now you’ll do the same for the IAT. Select ‘Intake Temperature Sensor’ at the top in the drop down box. (NOTE – If you are removing your MAF/AFM as a part of the DIYPNP installation process, do not recalibrate your IAT Sensor now)
            For the IAT, use the following table with a bias resistor setting of 2490 ohms:
            Code:
            14 / -10                  9500
            68 / 20                   2500
            176 / 80                  330
            Enter these values, and click ‘Write to Controller’. Now click Close to Exit.
            • Nitro Nick
              • Jan 2014
              • 268
              Code:
              14 / -10                  9500
              68 / 20                   2500
              176 / 80                  330
              Code:
              14 / -10                  9500
              68 / 20                   2500
              176 / 80                  330
              Ok i found the other day the drop down for the bmw 325. and hopefully that works. I haven't had a chance to check how accurate it really is since the gauge cluster is just a needle with no number readings.
              Also, as far as the IAT sensor goes. I wired in a GM sensor to the existing wires from the MAF sensor which was removed. Do I go along with this calibration process you listed. It is the standard gm IAT sensor that is recommended for megasquirt and I welded a bung in my intercooler piping about 8 inches from my throttle body. Let me know because i saw your note about the IAT sensor and it was slightly confusing.
              Thanks for the help.
                • 34839
                there's been a drop down in the menu of Tuner Studio for the E30 sensor for almost 10 years now. You don't need to manually enter them in. ;)
                also the IAT settings will depend on what IAT you are using. Since you can literally use anything, don't just take random settings off the internet. Find the sensor you have, and use the settings specific to it. Many people have used the GM sensor and it's already got a calibration in the Tuner Studio menu. Use that.
                • Nitro Nick
                  • Jan 2014
                  • 268
                  Code:
                  14 / -10                  9500
                  68 / 20                   2500
                  176 / 80                  330
                  Code:
                  14 / -10                  9500
                  68 / 20                   2500
                  176 / 80                  330
                  I tried doing this yesterday and it did not correct the problem...any other ideas of troubleshooting?
                  Anyone?
                  Sent from my SM-G935V using Tapatalk
                  • Nitro Nick
                    • Jan 2014
                    • 268
                    Code:
                    14 / -10                  9500
                    68 / 20                   2500
                    176 / 80                  330
                    Code:
                    14 / -10                  9500
                    68 / 20                   2500
                    176 / 80                  330
                    Still did not qork. Any other ideas? Faulty cts? I don't think it's Faulty because my stock gauge works fine...
                    • kyleconstantine
                      • Apr 2014
                      • 1380
                      I believe there are 2 seperate cts. One is a 1 wire that goes to the cluster. The other is a 2 wire that goes to the ecu/megasquirt.
                      • varg
                        Florida Turbo Man
                        • May 2014
                        • 3406
                        kyleconstantine is right, there are two sensors. Your sensor is probably bad. With the engine warmed up unplug the sensor and probe the sensor's pins with a multimeter, if the resistance is over 400Ω the sensor is bad.
                        IG @turbovarg
                        '91 318is, M20 turbo
                        • Nitro Nick
                          • Jan 2014
                          • 268
                          So the other day I took the e30 out for a ride. It had been out once during the winter when it was nice but yesterday was the first real time I took it out to mess around with the idle. I had replaced the Coolant temp sensor in hopes that it was the culprit. However even with a new CLT sensor the readings were still off. The gauge that I pull up in tuner studio says it only reaches about 60 degrees when warmed up. And I feel like this has to do with my idle issues as well. Basically I think its telling the PNP that my car isn't warming up when the gauge in the cluster is pegged right in the middle where its supposed to be. I tried re writing to the controller using the calibration drop down menu and selecting the e30 325i CLT and it didn't help.
                          I tried emailing whodwho but I know he is a hard guy to get a hold of.
                          Anyone have any ideas?
                          • Nitro Nick
                            • Jan 2014
                            • 268
                            I'm having a bit of trouble with this...any ideas?
                              • 34839
                              Sensor could be bad, or it could be the wrong sensor, or the bias resistor could be wrong. I've been using the settings in the drop down for years without issue.
