Knock sensors for M20 turbo/megasquirt
  • fergie
    • Jun 2017
    • 21
    Ive been contemplating the idea of knock sensors for my m20 turbo, as I would like megasquirt to control knock if it were to happen.
    Ive searched and searched, and have not found anything for if someone has ever done this before. So Im asking to see if anyone here has ever done this?
    My biggest concern is there doesnt seem to be a threaded location on the block of an m20 to install 2 knock sensors, thats my biggest issue.
    My tuner who I will be going back to for an ignition table adjustment said they can tune and listen for knock on the dyno, but for safe measures as Im running pump gas it is highly recommended for me to install knock sensors, since megasquirt can operate them.
  • nomansland92
    • 1657
    I use knock control on my m20 theres a threaded boss under the intake that works great.
    Sent from my SAMSUNG-SM-G891A using Tapatalk
    IX being restored here
    Ix turbo build here
    • fergie
      • Jun 2017
      • 21
      Care to elaborate? Does that mean you're only using 1 knock sensor in the middle of the block?
      Also are you using a generic knock sensor, and did you have to calibrate the sensor to the engines bore diameter etc?
      • nomansland92
        • 1657
        Ya just one sensor, I calibrated the frequency with the bore diameter then used knock ears to find the center of the frequency. Im not using megasquirt but its the same prinsible.
        Ix turbo build here
        • downforce22
          • Aug 2009
          • 3189
          what sensor are you using and what settings?
          • nomansland92
            • 1657
            Just a bosch 3 wire, can't remember the frequency off hand but I'm a 2.8l anyway.
            Sent from my SAMSUNG-SM-T817A using Tapatalk
            Ix turbo build here
            • e30davie
              • Apr 2016
              • 1788
              The frequency of the knock is dependent on piston diameter,
              Knock Frequency can be estimated from the piston diameter. The results of this calculation are only an estimate, but the result will be sufficient to greatly enhance the accuracy of your Phormula KS-3 or KS-4 Knock Detector.
              Years ago i made some DIY "knock ears", which was a nissan 2 wire knock sensor (ie a microphone), connected to an amplifier with a headphone jack.
              How good is the signal conditioning of the megasquirt? A quick google suggest you have to add a signal conditioning board, like so
              Enhance your MS3 ECU with this advanced knock module add-on board. Features programmable filters, per-cylinder adjustments, precise knock detection.
              reckons the bandpass is prorgammable, so you can program in the knock frequency from above. but not sure exactly how you program that board :S
              • fergie
                • Jun 2017
                • 21
                So Im going forward with knock sensor install on my M20. Since that threaded boss on the m20 black is m10x1.5 I was able to install a HeliCoil to bring it down to an M8x1.5 to install a N63 2 pin knock sensor.
                Ill be wiring it in possibly tonight or tomorrow and hopefully have it working before the e30 picnic.
                • downforce22
                  • Aug 2009
                  • 3189
                  please keep this updated, I would love to install a knock sensor on my turbo.
                  • fergie
                    • Jun 2017
                    • 21
                    So the knock sensor is installed and wired into megasquirt. I can plug in my headphones to the mspnp2 and listen for knock although there is alot of feedback from the valvetrain, so i suspect i will have to adjust the gain sensitivity.
                    I know the knock sensor works as i can tap on the block and pick up the audible sound of the knocking through the headphones.
                    • e30davie
                      • Apr 2016
                      • 1788
                      Did you set the knock frequency into the ecu somehow?
                      • DesertBMW
                        • Aug 2011
                        • 1023
                        Originally posted by fergie
                        Ive been contemplating the idea of knock sensors for my m20 turbo.
                        1986-1991 Saab 900 turbo, uses a stand alone boost regulating system that listens to the knock sensor and regulates boost according to the knock. It is called APC(automatic power control). You can install the system in your E30. APC brain box has potentiometers where you can adjust the sensitivity of the knock. There is also an LED light output where it will flash if it senses a knock. Very reliable and simple system, that you can buy for cheap. But I can only imagine this would be a hassle for you
                        • fergie
                          • Jun 2017
                          • 21
                          anybody have any info on how to setup the knock sensor? Im still trying to figure it out.
                          It appears to be getting 5 volts all the time, as when the engine running the knock frequency is at 100%, even tho the engine is just idling and confirmed to not be knocking.
                          • mr2peak
                            • 2388
                            By far the easiest way to get a knock sensor running with MS.
                            EFI, Fuel Injection, Auto, automotive, car, TPI, computation, ECU, MegaSquirt, GPIO, MicroSquirt, Sequencer, stim, MegaShift, MShift, DIY, transmission, 4L60E, 4L80E, controller, shifter
                            Drive it hard. Maintain it well.
                            A Topless Memorandum
                            • ForcedFirebird
                              • Feb 2007
                              • 8300
                              I have found the m20 will knock far after MBT.
                              john@m20guru.com
                              Links:
