Base Tune for Megasquirt
  • gespinal0301
    • Jan 2011
    • 317
    Hey guys, just wondering if anybody has a base tune floating around. I just finished testing my MS3X and everything seems to working. Just need a base tune to really dive deep into testing.
    From there I'm making a plug & play adapter board, then I'm going to 3D print an afm connector and O2 connector so I can run those through the stock wiring ;D;D
    My Daily Driven 318is
  • e30davie
    • Apr 2016
    • 1788
    lots of tables in there.
    Not sure about actual msq files though. if you can get it running by inputting the setup settings manually, you can just put all those numbers into your maps.
    • Kershaw
      • 11822
      MegaSquirtPNP Plug-N-Play Standalone Engine Management Systems by DIYAutoTune.com
      AWD > RWD
      • gespinal0301
        • Jan 2011
        • 317
        Forgot to mention this is for an M42, I've seen a lot of m20 bas maps floating around though. I'll keep checking the links to see if I find one!
        • Kershaw
          • 11822
          I think you're on your own there. I haven't seen another m42 running MS.
          AWD > RWD
          • varg
            Florida Turbo Man
            • May 2014
            • 3436
            Well I had one for a while, so I can help out here
            IG @turbovarg
            '91 318is, M20 turbo
            • gespinal0301
              • Jan 2011
              • 317
              I figured eventually you would chime in haha I'm still at FAU if you ever want to meet up!
              Im done building the MS just having an issue getting the VR signal now
