So, this is strange.
I had the emulator running while my son drove us over to the mechanic so I could use the lift to change the master brake cylinder (and then bleed the brakes).
The emulator is not changing RPM cells with acceleration.
The tachometer is working.
Does the tach get its signal from a source than the ECU?
I will futz with the connectors under the intake manifold. And try a different CPS.
