$880 to replace exhaust hanger?
  • jdusty4
    • Jun 2006
    • 96
    Forgot to post the name of this shop. Doing so now to help others avoid. Manhattan Auto Care at 275 Delancey Street in NYC
    • kyleconstantine
      • Apr 2014
      • 1380
      Damn you could have got a nice used welder for that price.
      • Vincenze
        • Apr 2019
        • 972
        It can take hours to unscrew the rusted exhaust bolts that connect the exhaust and the middle section.
        • e30austin
          • 15382
          this has nothing to do with the conversation.
          • moatilliatta
            • 6123
            Without an actual Invoice arn't we all clueless.
            @Zakspeed_US
            • Vincenze
              • Apr 2019
              • 972
              Well, the topic's author wanted to change the 3 exhaust hangers.
              The 2 original BMW hangers and the BMW rubber rings cost $293: https://www.ecstuning.com/b-assemble...18211707923kt/
              The third hanger is $59: https://www.ecstuning.com/b-genuine-...t/18211712511/
              Parts total: $352 plus tax.
              It's definitely easier to change the exhaust hangers when the exhaust is disconnected.
              One of the hangers can be replaced easily. But the second one will need a lot of clearance, and possibly the heat shield removal.
              • ForcedFirebird
                • Feb 2007
                • 8300
                After releasing the hangers, remove the two trans cross member nuts and let the engine tip back. The muffler will be two feet from the sub frame - plenty of room - I do it all the time at work (also when needing drive shaft access) since the exhaust nuts/bolts are often rusted to oblivion.
                john@m20guru.com
                Links:
