Things to improve for over 350Hp
  • Gabriel30
    • Feb 2026
    • 10
    Hello everyone, I have an M20B25 with an 8.8:1 compression ratio. I want to build a turbo setup with a stock bottom end, but I’m aiming for a bit over 350 HP. I already have a GT35 China turbo from some time ago and a large intercooler (600 / 300 / 76).
    My plan is to gather all the parts first and then start the project. The engine will be refreshed with new piston rings, and I will also install a waste-spark ignition system.
    My question is: what really makes the difference when trying to make a bit more power, just over 350 horsepower? I’m thinking maybe doing something to the cylinder head? I’m also considering a slightly thicker MLS head gasket to reduce the compression a little more.
    If you have any advice for me, I would really appreciate it. Thank you!
  • Gabriel30
    • Feb 2026
    • 10
    Nobody ??
    • hasa
      • May 2013
      • 302
      You need a standalone engine management like Maxxecu or similar. Then +400cc / 40lb injectors. Sachs 618 clutch. Good tune on a dyno. Then you have 350hp.
      • Gabriel30
        • Feb 2026
        • 10
        What head gasket should I use?? Thank you !
        • hasa
          • May 2013
          • 302
          I would try normal head gasket. You don't need more than 1bar / 14psi boost. If it fails, then add cut rings and still use std gasket.
          • Gabriel30
            • Feb 2026
            • 10
            Do you know where I can find those rings? I’ve looked but nothing.
            • hasa
              • May 2013
              • 302
              Look this article about "Fire rings": https://5150autosport.com/blogs/prod...26gFFf5HBXDyrh
              Tool for machining the rings is Isky Groov-o-Matic for example (this is what I've used). They probably supply also the wire that is used to make the ring.
              • It's Soda Not Pop
                • Jan 2022
                • 875
                Also not sure of how much you have read through this forum. But there is a lot of knowledge that has already been posted on here. Do a little digging and you'll find your answers.
                88' Seta 2.7i Zinno
                https://www.r3vlimited.com/board/for...430-my-88-seta
                • varg
                  Florida Turbo Man
                  • May 2014
                  • 3374
                  Nobody jumped in quickly because in 2026, such basic questions are unnecessary after doing basic research. There have likely been dozens of pretty good turbo M20 build threads at this point. Easy mode, you could pick a build thread where someone did what you want and just copy it. There's no need to reduce compression, you'll just kill your responsiveness, there's no need to use an MLS gasket, there is questionable value in having head work done because it's expensive. If your chinese GT35 is a journal bearing knockoff of a 30 year old design you'd be better off with a decent properly sized ball bearing turbo than buying a well ported head and using a cheap turbo. You'd feel better gains out of a quick spooling and not oversized modern turbo than the best head work money can buy with a chinese GT35 knockoff.
                  IG @turbovarg
                  '91 318is, M20 turbo
                  • Gabriel30
                    • Feb 2026
                    • 10
                    I did research, but there are so many opinions out there, and a lot of builds went one direction and then ended up having issues with head gaskets or later switched to a more powerful setup. That’s why I made a post — to find out, now in 2026, what the most proven build for an M20 would be and to try to avoid other people’s mistakes.
                    I’ve read dozens of pages, and even though at first I was focused on a specific setup, the more I kept reading, the more unsure I became. I’m sorry — I know this question is somewhat basic, but I was just looking for some proven and constructive ideas.
                    • varg
                      Florida Turbo Man
                      • May 2014
                      • 3374
                      Most head gasket failures in turbo M20s are due to poor or aggressive tuning. If you o-ring or MLS you lose the head gasket as the weak link and your next weak link is your pistons, and MLS have a bad reputation for leaking. Some of the higher profile builds that have blown stuff up repeatedly here were very abusive drivers or pushing limits. With an aggressive tune or abuse anything you do is on borrowed time. In the end the best bet for long term enjoyment is to build for response and broad torque curve, find a reputable tuner, go for it on the dyno, then dial it back some for longevity.
                      IG @turbovarg
                      • Gabriel30
                        • Feb 2026
                        • 10
                        Thanks for the answers. I’ve decided to go with a stock head gasket, new piston rings, new bearings, a machined head, and possibly some HD rockers—and that’s about it for the engine. I’ve seen that this is a fairly safe setup for 300–350 hp.
