Noob questions! Wanting to turbo my M20. School me on the turbooos r3v!
  • ///mfizzle
    • 36
    Hey guys,
    Ok so I want to turbo my E30. I didn't see an FI section on the forums so I figured I would post here.
    The car is a 1991 325i with 136K miles. Timing belt and water pump just replaced. All kinds of other maintenance done here at the dealership. The engine is in tip top shape.
    I want to turbo it stock. I would do a head gasket (I'm not even sure if that's needed on these engines) But that's about it.
    So just a couple questions.
    1. How much is this going to run me? $1K? $2k? $4k? I don't mind buying a used kit. Nothing fancy, I just want around 250whp. and a COMPLETE bolt on kit. Is the M20 even capable of that power on stock block?
    2. My car is an automatic, so I would be converting it into manual. Will an E36 M3 Transmission bolt up to the M20? I'm not a big fan of the E30 manual transmission.
    That's pretty much it. I appreciate any help!
    :ohsnap:
    Alpine white E39 ///M5 = Weekend Car.
    1991 Alpine white 325is = Daily Driver
  • Hick
    • Sep 2005
    • 6451
    Originally posted by ///mfizzle
    Ok so I want to turbo my E30. I didn't see an FI section on the forums so I figured I would post here. :
    Originally posted by vlad
    • ///mfizzle
      • 36
      Bahahhaa. My bad. Sort of missed that one
      • 325ix
        • Aug 2009
        • 7783
        Wasn't it you that said you wouldn't convert to manual because your E30 would be a dd?
        • Emre
          • Sep 2007
          • 1228
          Serious thread, or bad joke?
          1987 Mercedes 190E 2.3-16: Vintage Racer
          2010 BMW (E90) 335xi sedan: Grocery Getter
          • lambo
            Captain Scene Points
            • 10953
            Originally posted by 325ix
            wasn't it you that said you wouldn't convert to manual because your e30 would be a dd?
            +1?
            • ///mfizzle
              • 36
              Yes. But now I think I'm buying a different daily. E46 most likely.
              Serious. I just need some help. I don't know much about these older engines and have no idea where to start.
              • ak-
                • 12422
                Bottom end will be okay for those goals.
                A "kit" doesn't really exist. eBay ones are just generic crap put together for you that is usually.. well, crap. You have to most likely peice your own.
                E30tech.com will answer all your questions
                R3v is a swap forum mostly :o
                1991 325iS turbo
                • TurboJake
                  • 3780
                  I don't know who your kidding. The getrag 260 is a fine transmission...
                  Leave Me Transaction Feedback
                  • Kershaw
                    • 11822
                    old engine, new engine. doesnt matter.
                    the concept and parts are the same: s54, m10, renesis 13b, vq35, etc...
                    go here for what you need to know:
                    http://tinyurl.com/3gnea5g
                    AWD > RWD
                    • lambo
                      • 10953
                      Or here.
                      • ///mfizzle
                        • 36
                        Thanks for the replys guys!
                        Ok thanks for the answer :D
                        I'll join up over at e30tech. I won't be going with an ebay kit. Seems like there's a lot of mixed feeling on them!
                        Maybe I just have had bad experiences with my recent E30s. I tried everything to get rid of shifter slop and couldn't for the life of me. The 5 speeds in both of them felt horrible.
                        Sweet! Thanks! :p
                        Originally posted by lambo
                        Thanks mang! Looks like I've got some reading to do!
                        • 325ix
                          • Aug 2009
                          • 7783
                          Before you do anything, go to e30tech and read until your eyes bleed.
                          • ForcedFirebird
                            • Feb 2007
                            • 8300
                            Drive across the alley and our shop can put something together for you :)
                            john@m20guru.com
                            Links:
                            • ZekeTheSneak
                              • 1562
                              Mane issue is finding a fuel management. Stock with piggy backs is just retarded in my book go standalone. Comedic headgasket to be safe
