The trick with ARPs is following the directions. Seriously. Use plenty of the lube they give with the studs and follow the recommended procedure. Ive never seen someone pull a random torque spec and method out their azz that works better than the one developed in the laboratory.
At your power level the OEM gasket is most likely the best bet and is the most tolerant. MLS gaskets need a freshly decked surface thats very smooth to seal properly.
An engine is an engine. There really isn't a lot of difference from one engine to the other. BMWs are not mystical or magic compared to anything else.
