From knowing nothing to having a Thunderbird supercharger on an m20b27i
  • Ether-D
    • Sep 2011
    • 2838
    #301
    No worries.
    Got the belt and pulleys on and I wired the IAT sensor in to where the airflometer connector was.
    Now I need to install the O2 sensor and controller and gauge. Then the 24.5lb injectors. Then I can get the Msquirt in there and get her started. Then tune for a bit.
    Then the pump & reservoir and plumbing & electric for the intercooler. Then hood scoop. Then more tuning.
    Originally posted by Andy.B
    I was born on 3/25…
    • codrum
      • Jan 2011
      • 279
      #302
      Originally posted by Ether-D
      For reference, if anyone else wants to use the ebay VW AIT ($7 and it has the same style connector as everything else in your bay) instead of the GM one ($20, plus awful fugly GM connector) for MS. I also checked my factory coolant temp sensor for gits and shiggles. Here are my findings.
      Degrees (F) = ohms
      OE coolant temp sender:
      27.5 = 6000
      71 = 2300
      220 = 220
      VW IAT sensor:
      32 = 4340
      68.7 = 2700
      220 = 190
      This is good info, I wish there was a repository somewhere that stored this (or a list of OE sensor datasheets). This would come in handy with my project when testing out other sensors, thanks for posting it.
      • Ether-D
        • Sep 2011
        • 2838
        #303
        ^You can do this for any thermistor type temp sensor. Just dunk it in ice water 32f (record reading with digital meter), boiling water 220f (record), and known room temp (record). Plug the numbers into ms and you're done. There are so many more styles than the GM one. I got a much better option for my setup because it's much lower profile and has the same connector as the rest of my engine. And Thanks!
        I was born on 3/25…
        • Q5Quint
          • Jan 2005
          • 725
          #304
          dont let the doubters doubt your hood scoop. They are correct in that there may be more efficient ways, but it will help a little as long as it is out in the air flow.
          I had a massive 3" intercooler on my turbo and I had almost ambient IAT most of the time even after flogging it..... as long as I was moving. If you end up sitting in traffic a while it will always climb unless you have a big fan.....
          I am going to use a slightly less giant intercooler this time and then rig up some ghetto h20/alchohol injection. If you are afraid to squirt directly into your engine like she is some crazy ex-gf who would lie about birth control, you can always squirt the outside of the cooler, too.
          • Ether-D
            • Sep 2011
            • 2838
            #305
            I think I'm gonna make my own scoop. Out of black walnut. I glued it up last night, and I'll start shaping it this evening I think.
            I was born on 3/25…
            • TheTacoMan
              • Nov 2011
              • 2308
              #306
              HA. Great way to put it.
              Sti if im not mistaken had intercooler sprayers stock. It does help!
              Did I read that right, wood hood scoop? Sounds kinda cool
              • Ether-D
                • Sep 2011
                • 2838
                #307
                It could be cool, IDK bro, We'll just have to see. It'll go with my hard top roof rack…
                Also I now have the cable and adapter for the squirt. I'm about to be almost ready to start thinking about considering looking into the possibility of starting this thing soon.
                I was born on 3/25…
                • Ether-D
                  • Sep 2011
                  • 2838
                  #308
                  It starts!!!
                  I was born on 3/25…
                  • Ether-D
                    • Sep 2011
                    • 2838
                    #309
                    Omg omg omg omg
                    omg.
                    I was born on 3/25…
                    • LJ851
                      • 7918
                      #310
                      The vids aren't loading ?
                      Lorin
                      The M30 is God's engine.
                      • Ether-D
                        • Sep 2011
                        • 2838
                        #311
                        I think I can tell my phone to put it on FB. I'll try.
                        I was born on 3/25…
                        • TheTacoMan
                          • Nov 2011
                          • 2308
                          #312
                          Videos?!
                          • agent
                            Vice Grand Pubaa
                            • 7960
                            #313
                            Originally posted by kronus
                            • Ether-D
                              • Sep 2011
                              • 2838
                              #314
                              Try this:
                              0 views, 17 likes, 0 loves, 20 comments, 2 shares, Facebook Watch Videos from Jacob Crawford: So, I put a supercharger on my car. I built this from junkyard parts and country smarts.
                              I was born on 3/25…
                              • agent
                                Vice Grand Pubaa
                                • 7960
                                #315
                                Hooray!
                                Bonus points for Spaz being the first to comment.
