Brodeo.... my god. I am in. Thanks for the heads up on my springtime goals.
There is also a springtime meeting literally this weekend. Cant make it but now I know to check. Thanks!
MS does seem expensive... but my god the plug and play is so worth it. I probably spent 300-400 my first time around buying a used one and splicing everything into a relay board to make it work. You know, just in case I ever wanted to go back?
I then spent probably $10,000 in hours trying to figure out what the hell I had soldered wrong, or what connection was loose, or why 1/2 my injectors were just open 100% of the time spraying fuel onto my turbo and melting my cat (cracked relay board, heh).
It was a great learning experience sure, but once you call Keith you never want to go back.
Is "twin-charging" anything like "night crawlers"? If so then yes.
