Slightly Overbuilt E30 2014
  • Good & Tight
    • Apr 2004
    • 2057
    #91
    Originally posted by BMWSOB
    I also decided against the hood exit. Its just too ugly for me. I had the hood taped and marked for the hole and I just couldn't do it.
    I did get the last piece to the puzzle!! Custom 4" Mark Williams 6061- T6 Driveshaft.
    Hopefully its strong enough!
    Damn 4" is huge. What size U-joints, are they 1410 ? I have a 3" with 1410 on the rear and had to grind down the ends of the yoke and inside the sub-frame to make it fit.
    Looks great though, good choice on not putting the exhaust through the hood.
    Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
    ____________________________
    E-mail Panayiotisx2@gmail.com
    Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
    • BMWSOB
      • Dec 2005
      • 311
      #92
      It looks way bigger in person.. ;) They are 1350s. I put the e46 m3 rear in my car so the subframe is all hacked up anyway. Should just need a little clearance on the old center support bear mounts. Oddly enough with the length of the trans, I could have used those for the driveshaft loop mount...
      MaximumPSI.com
      • DER E30
        • Sep 2013
        • 2349
        #93
        That shaft is almost as big as the headlight... WOW
        -Christian
        • BMWSOB
          • Dec 2005
          • 311
          #94
          Yes, It literally looks twice as big in real life.. lol I'd even venture as far to say girthy.
          MaximumPSI.com
          • Good & Tight
            • Apr 2004
            • 2057
            #95
            It's a tight fit with the 3", the driveshaft loop needed some modding to work.
            I know you'll git ir done and make it fit you crazy SOB.
            In for track vids....!!!!!!
            • BMWSOB
              • Dec 2005
              • 311
              #96
              My driveshaft loop was custom before. I think I might be able to reuse it depending on where I can mount it. We shall see.
              MaximumPSI.com
              • BMWSOB
                • Dec 2005
                • 311
                #97
                It does fit with a little body massaging. Trans mount, gas pedal, and assemble the rest!
                MaximumPSI.com
                • alexlandro
                  • Mar 2014
                  • 69
                  #98
                  Just read the entire thread, mind blowing. Probably one of the rare e30 to run low 9s...
                  http://www.r3vlimited.com/board/showthread.php?t=319393
                  • BMWSOB
                    • Dec 2005
                    • 311
                    #99
                    Thanks brah. There are a hand full out there, just takes money and persistence.
                    MaximumPSI.com
                    • Simple_Smith
                      • Aug 2011
                      • 585
                      #100
                      buuuuuhhhhhhhhhhhh
                      1989 JDM-Tech 2
                      2010 335 D for daily
                      • Spectre
                        • Aug 2013
                        • 41
                        #101
                        I'm not that familiar with Lenco trans, what is the benefit of your shifter vs. the levers? I assume it's quicker (You wouldn't have to reach up and grab the next lever) but I may be wrong.
                        This build is awe-inspiring man, Sub'd!!
                        • BMWSOB
                          • Dec 2005
                          • 311
                          #102
                          Made over 1000whp on the dyno, dropped a stock valve and ate the motor.
                          Small update to the e30 life.
                          Block is at the machine shop. Waiting to get the turbo back from Comp for upgrades.
                          m52-s52-cat 282/274
                          this collector is waiting for its brothers to show up.
                          These should be coming soon locally from a shop called New Development Fab
                          MaximumPSI.com
                          • LJ851
                            • 7919
                            #103
                            That collector is ridiculous.
                            Congrats on the 4 digit power ! Do you know why the valve gave up?
                            Lorin
                            The M30 is God's engine.
                            • BMWSOB
                              • Dec 2005
                              • 311
                              #104
                              Yea, it was just a random set of stock valves that has seen lots and lots of rpm and rev limit at 8400rpm on hydraulic lifters. They were well passed their intended life span apparently.
                              MaximumPSI.com
                              • CorvallisBMW
                                Long Schlong Longhammer
                                • 13039
                                #105
                                Jesus. Tapdancing. Christ.
