What tuning software is best for a tight budget?
  • e3irsty
    • Jan 2014
    • 134
    Simple question W.A.R. chip or MS? Want to boost my M20 on a tight budget, I will want to tune myself so which one is easier to tune because of lack of knowledge when it comes to tuning.
  • Lithium
    • Mar 2012
    • 88
    I use a Moates emulator & Tunerpro with a Innovate Motorsports wideband
    Car, Tuning, ECU, ECM, PCM, Calibration, Modify, Scan, Scanner, OBDI, OBD1, OBDII, OBD2, GM, General Motors, Ford, Subaru, BMW, Renault, Volkswagen, VW, Motronic, LT1, LB9, L98, Firebird, Camaro, Mustang, Moates, Buell, Ducati, Nissan, DSM, Mitsubishi, Diamond Star Motors, EECV, EEC V, EECIV, EEC IV
    The newest breed of emulator has evolved!   Note: When using with 24-pin GM applications, you MUST use a Socket Booster! (available separately). Note2: If you'd like to have a custom length cable instead of the standard 18" (for example, 2" or 6" for noise or latency-sensitive applications such as VW or Nissan), please
    http://www.innovatemotorsports.com/products/lm2.php
    I Love my Bimmer. :up:
    http://www.r3vlimited.com/board/showthread.php?t=316184
    • MaxBell
      • 1391
      So this Ostrich replaces the ECU? I can plug and play with an M50? Do I have to swap coils or anything stupid?
      REMEMBER: Be safe and have fun is Rule Number 1.
      The Epic Unbuild of Clint Eastwood
      • kistler#7
        • Jun 2013
        • 186
        Megasquirt all the way. You can build a megasquirt 1 for under $200 and the tuning is way more accurate
        Sent from my SPH-L710 using Tapatalk
        m20b27 Turbo. Hx35. Twinscroll Mani. MS1. 42lbers
        http://www.r3vlimited.com/board/showthread.php?t=338818
        • Lithium
          • Mar 2012
          • 88
          It replaces the ECU chip only - plug n play (No other changes req'd)
          But
          (Megasquirt is worth looking into for sure)
          • The Dark Side of Will
            • Jun 2010
            • 2796
            *IF* you have a complete definition file for the program on your chip, OE DME is FAR more capable than MS1.
            Definition files exist for a large number of OBDI GM applications. MS is a waste of time on those applications because the stock ECM is so much more sophisticated.
            • kistler#7
              • Jun 2013
              • 186
              What can the unlocked motronic do that megasquirt cannot? Or what does it do beter? I have not heard many say afm > speed density
              • Sirotto
                • 317
                Get a big cup of coffee and start reading
                "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery." - Winston Churchill
                "People sleep peacefully in their beds at night only because rough men stand ready to do violence on their behalf" -George Orwell
                  • 34839
                  no. absolutely, no. Motronic is ancient. I don't love MS1 (spend the extra $80 for an MS2 CPU, it's worth it) but Motronic can't hold a candle to it.
                    • Jun 2010
                    • 2796
                    Interesting. I thought that with a WAR chip and MAF conversion, the Motronic would be comparable to the OBDI GM hardware, which has been hacked well enough that it can run engines with 4 digit power and single digit timeslips.
                    • digger
                      • Nov 2005
                      • 6127
                      big hp and going fast says nothing about an ECU IMO.
                        • 34839
                        no, even the best MAF systems for Motronic are still pretty buggy, because MAF based algorithms and what Motronic uses (closer to speed-density) are very different.
                        aside from that, the resolution is poor and Motronic is pretty damn slow. no real time tuning, no datalogging, narrowband sensors, switch based TPS, no acceleration enrichment, etc.
                        • wazzu70
                          • Jan 2005
                          • 1143
                          Very wise statement.
                          -Nick
                          M42 on VEMS
                            • Jun 2010
                            • 2796
                            If you drive it to the strip and back, it can... ;-)
                            With a 3 bar MAP sensor and hacked code, a $30 7730 can run Hi-Z injectors on a big power small block Chevy, or a $50 7749 can run Lo-Z injectors on same.
                            Of course they also need ~$300 emulator and tuning software, but result in very good drivability as well as high power. The biggest shortcoming is that the GM OBDI VE tables stop in the realm of 5000 RPM, except for the Quad 4 code masks... but those were never boosted.
                            I didn't know Motronic was that primitive.
                            • Jaxx_
                              • Dec 2009
                              • 1880
                              DIY SLC from 14point7.com is the AFR meter that I went with, it was the cheapest wideband I could find.
                              I got 315cc/min injectors from one of my old cars, a turbo volvo, and threw them in the fuel rail. paired with megasquirt, it's overall been pretty damn cheap for a standalone.
