Highest HP Stock bottom end m20
  • cream_e30
    • Oct 2018
    • 30
    Hey, I am new here, have a turbo e30, a friend and I were talking about the m20 motor and we were wondering what the highest HP stock bottom end m20 is?
    Did some googling but didnt come up with much.
  • Zambuzan
    • Nov 2017
    • 434
    I think the "i" bottom has highest HP. "i" has the (75 stroke, 84 bore, 8.8 CR). There's also the sETA and the ETA (81 stroke, 84 bore, 10.3 CR?). The ETA head is very restrictive compared to "i" head. I believe the sETA is the ETA but with "i" piston heads (don't quote me on it though). Better information is out there tho.
    "Time doesn't heal anything... It just teaches us how to live with the pain." - My Cracked Dashboard
    • cream_e30
      • Oct 2018
      • 30
      Oh definitely. More looking for results of what the highest number guys actually pushed out of stock internal m20’s. Like I made 450, but someone must be higher than that.
      • E30-Ellerman
        • Oct 2015
        • 212
        Friend of mine is running 17 psi with meth injection and has been for 3 years without issue. He's at like 380-400 whp. It's really quick.
        I think I've seen higher, not sure how reliable that would be though. That's on a complete stock bottom end and head with ARP head studs and an Elring head gasket.
        2016 F-150
        1987 Royalblau 325es B25 turbocharged
        Build thread here: http://www.r3vlimited.com/board/showthread.php?t=405594
        • cream_e30
          • Oct 2018
          • 30
          Nice! Yeah that’s what I’m looking for. Want to see what guys are actually putting down. I know full custom m20 can reach 1000, but seeing a stock bottom do good always impressed me
          • nomansland92
            • 1657
            I've heard of a few at 500 but I believe that's pretty much the limit of the rods and pistons. so hard to say when numbers can easily vary 15% from different dynos
            Sent from my SM-G892A using Tapatalk
            IX being restored here
            Ix turbo build here
            • SLEEPYDUB
              • 658
              I ran 30psi for a limited time only on a 6266 with E85. Stock B25. Probably made close to 550whp. I slung a rod through the block sitting it on the limiter at that power level. No idea if it would have held up had I been a bit more gentle on the limiter.
              Currently my stock 2.7 bottom is holding about 20psi on a 6266 which should be close to 450whp
              - AXIS POWERS - 2JZ E30 Build
              Current Project - 87 325is 2JZ Swapped with M4 DCT
              • Jaxx_
                • Dec 2009
                • 1880
                I'm curious--how much timing?
                • cream_e30
                  • Oct 2018
                  • 30
                  Yeah I am curious too. I was pulling mad timing for 440hp.
                  • pazi88
                    • Sep 2015
                    • 584
                    He's running e85, so the timing is probaply quite high still.
                    • SLEEPYDUB
                      • 658
                      Not as much as you think. At 200-250kpa, between 4000-7000 i run 18* going up to 21*
                      I think I am actually leaving a ton of power on the table and bump that up 2-3* or more
                      • cream_e30
                        • Oct 2018
                        • 30
                        What ecu are you using?
                        • SLEEPYDUB
                          • 658
                          Ms2
                          • varg
                            Florida Turbo Man
                            • May 2014
                            • 3401
                            That is a good amount of advance. I run 14°-16° at 200kPa.
                            IG @turbovarg
                            '91 318is, M20 turbo
                            • SLEEPYDUB
                              • 658
                              What kind of fuel? Im also on a 2.7 bottom end with an 885 head so they require more timing then a normal 2.5/885. And I use E85
