M10 knowledge.
  • thebutterson
    • 463
    #181
    Unless you're really hard up on a certain sound, you can probably get your exhaust done for a good bit less by ordering parts from summit or jegs and having an exhaust shop put them in with mandrel bent tubes.
    • E30_Pare
      • 7801
      #182
      I see your point. I was just planning on having the catback & headers flanged. So I can switch between a cat & test pipe.
      DREWLIENTE
      1$ PShops PM me
      • Holland
        • Nov 2008
        • 7212
        #183
        Whatever you do don't get a magnaflow, it sounds like total ass on my m10.
        Originally posted by DEV0 E30
        • Jaxx_
          • Dec 2009
          • 1880
          #184
          megasquirt msq file... here you go.
          MS2extra 2.1.0
          NA m10b18.
          no iacv
          no tps
          edis coil driven by direct coil control, on spark a and spark b, D14 / D16.
          coolant fan relay driven on Fidle (activates at 190F, cools to 180F)
          launch control input on JS10 for 2-step
          • E30_Pare
            • 7801
            #185
            Ive heard the dynomax super turbo. Sounds nice. I've just got a generic can that just died. I can hear popping & backfiring at 3-4k. Is that normal? Lol
            DREWLIENTE
            1$ PShops PM me
            • Robotin
              • Jun 2011
              • 4471
              #186
              im sure this had been covered. but if i decide to convert a carbureated m10 to EFI. can i just throw on the m10 head all the top end stuff? or is there more involved?
              1989 325i SETA stroker [delphin] R3V'd 8/31/2011
              1989 325ix [zinnoberrot] $OLD
              1970 2002 [Nevada]
              Originally posted by Herr Faust Schinken
              guy must have slid into something that doesn't look like a car vs car hit
              Originally posted by ak-
              Must of slid into Rob
              • E30_Pare
                • 7801
                #187
                All I've seen on the conversion is a lot work for minimal gains.
                DREWLIENTE
                1$ PShops PM me
                • Hey_You
                  • Nov 2009
                  • 963
                  #188
                  I really like my exhaust system. Header, 2.5" piping back to a Vibrant muffler (The "Stealth" black one). Sounds beefy. Next extra cash will convert to MS, so Jaxx, may be hitting you up with some questions when it comes time.
                  85' 318i ~The Bronze Bomber (FrankenM10 with a Forced Future :wgaf:)
                  • thebutterson
                    • 463
                    #189
                    You'll probably need an electric fuel pump.
                    • E30_Pare
                      • 7801
                      #190
                      How high on the loudness factor?
                      DREWLIENTE
                      1$ PShops PM me
                      • Robotin
                        • Jun 2011
                        • 4471
                        #191
                        alright. sounds good.
                        im gonna jump on the complete other end on this.
                        how hard would it would to convert an m20 to carburator?
                        i know that the m20b20 was careburated. so couldnt u basically swap all that stuff over to a b25? let me know!
                        1970 2002 [Nevada]
                        • thebutterson
                          • 463
                          #192
                          This is the M10 forum.
                          This thread is titled "M10 knowledge".
                          • Holland
                            • Nov 2008
                            • 7212
                            #193
                            I'm thinking of a similar setup. Have any sound clips?
                            • E30_Pare
                              • 7801
                              #194
                              Lol a little list there ey rob? Lol. I guess it's all about reverse engineering. Carbs throttle linkage adapters management.
                              DREWLIENTE
                              1$ PShops PM me
                              • Hey_You
                                • Nov 2009
                                • 963
                                #195
                                I have an old clip from when I first had it done, but that was just an idle/low rev clip. I'll get another one that's current now that the exhaust has broken in (and after I patch the hole in my header from rubbing).
                                Here is when I first had it done
                                Exhaust
