E30 M20 Electronic Fan Radiator Shroud
  • Rockonp04
    • Sep 2020
    • 75
    Does anyone recommend an electric fan radiator shroud that works with the 16" Spal fans? Wanting a shroud that goes in with minor modification.
  • slippery
    • Nov 2011
    • 379
    Cant you use the factory one?
    • moatilliatta
      • 6158
      I've bought the mishimoto fans kit for E36 and removed the mishi fan and put on a spal. Cut off the bracket for e36 tank, and now you have an alright fan holder, not shroud though.
      Zionsville Motorsports used to make some crazy shrouds that held fans.
      @Zakspeed_US
      • Rockonp04
        • Sep 2020
        • 75
        Has anyone used this radiator and shroud setup?
        Yonaka carries a full line of high performance parts for your ride. Since 2001, we have been a source for grassroots performance enthusiasts. Our products are for Acura, Aston Martin, Audi, BMW, Eagle, Ferrari, Ford, Honda, Hyundai, Infiniti, Lexus, Mazda, Mini, Mitsubishi, Nissan, Porsche, Scion, Subaru, Toyota, and Volkswagen.
        • varg
          Florida Turbo Man
          • May 2014
          • 3439
          For $400 complete you'd hope the shroud wouldn't have big honkin' gaps that you can easily see in the product pictures... I have doubts that will actually fit a 6cyl E30 at all. If those gaps go all the way around that is a pretty crappy shroud and should have some sealing strips. Keep in mind that clearance makes it harder to make an effective fan shroud that allows the fan to pull air across the entire area of the radiator, especially if you have an upgraded radiator that is thicker than stock. Most people just bracket the e-fan directly to the radiator, and a 16" fan's swept area is around 60% of the radiator core's area which is not terrible.
          IG @turbovarg
          '91 318is, M20 turbo
          • moatilliatta
            • 6158
            The fan really is working when you're below 35mph or so.. If you don't have flaps to let air pass through your killing your efficiency of cooling over 35mph when at speed.
            https://www.mishimoto.com/bmw-e36-pe...1992-1999.html
            I don't mind their fan controller either, you can get with an NPT sensor
            Take mishimoto fan off, cut off useless tabs, put Spal on. Usually have to bend to get a nice tight clearance to radiator, I usually put thick foam around fan bracket so it makes a seal to radiator. Rock out. I put fan controller sensor in head on race car, in radiator on street car.
            @Zakspeed_US
            • dvallis
              • Oct 2015
              • 1474
              "And then we broke the car. Again." Mark Donohue, "The Unfair Advantage"
              1987 E30 3L Turbo Stroker Das Beast
              2002 E39 M5
