SPAL temp sender placement?
  • grantmiller1
    • Jun 2017
    • 52
    I have the SPAL wiring kit from Race German that has a beefy temperature sender included (185F) with 3/8 NPT threads and about 16mm diameter. As the temp sender is fairy large, it will not fit in my thermostat housing.
    Race German says you've got to weld a threaded hole into your radiator to support this. Ugh.
    I'm looking at doing this differently and finding a in-line radiator hose adapter that I can put the temp sender into.
    Something like this: https://www.ebay.com/itm/33414654609...UAAOSwW5BgIeZX
    But everything out there is 1/8 NPT and the SPAL sender is 3/8 NPT.
    Has anyone done something like this for their electric fan setup?
    Yes, I am trying to preserve my AUX fan wiring/control/temp sender as I have A/C in my car.
    Thanks
  • slippery
    • Nov 2011
    • 379
    What about an adapter?
    https://www.amazon.com/dp/B008214L0Y...EQKPZ42N00X4SS
    • grantmiller1
      • Jun 2017
      • 52
      Originally posted by slippery
      That idea did cross my mind, but the temp sender is pretty long. I'm not sure if it would even engage the threads before it bottoms out in that fitting.
      My other idea is to just get a in-line radiator hose adapter (with the correct I.D. for the hose) and see if a local machine shop can bore out the temp sender hole to fit my gigantor temp sender.
      • Jaxx_
        • Dec 2009
        • 1880
        Is the sender a switch or a NTC sensor? I would opt to replace it with something 1/8 NPT
        • grantmiller1
          • Jun 2017
          • 52
          It looks like a temp sender, but it's a also a switch.
          I have seen some kits with a 1/8 NPT switch/sender, might give that a try.
          • moatilliatta
            • 6158
            I usually put them in the head on race cars and in the output side of the radiators like factory on street cars. A 1/8 npt inch should be a be available and autometer makes metric to npt adapters.
            @Zakspeed_US
            • Jaxx_
              • Dec 2009
              • 1880
              How many pins does it have? if it is only 2 and there isn't any smart box to control the fan you can probably safely just find another thermo switch.
              • grantmiller1
                • Jun 2017
                • 52
                It's only one pin. I'll look for other thermo switches that are 1/8 NPT.
                • varg
                  Florida Turbo Man
                  • May 2014
                  • 3439
                  You may be able to find an M14x1.5 to 3/8NPT adapter that will screw into the stock fan switch port.
                  IG @turbovarg
                  '91 318is, M20 turbo
                  • ADEN
                    • 620
                    Out of curiosity, Why not using the stock aux fan circuit to connect any custom fan, You may replace radiator switch with lower temperature switch like for example 75C?
                    I am planing to try this with the stock aux fan after deleting the clutch fan.
