Cleaning valve train
  • Hoffbrohaus
    • Sep 2013
    • 519
    I have the valve cover off to put in ARP studs and do a valve adjustment and wanted to make sure it's ok to clean the valve train? I'm thinking just brake cleaner but wanted to be sure it's ok. I saw this valve train in an article online, so clean!:
    vs this one from Pelican parts which looks like mine:
    '90 325is
  • varg
    Florida Turbo Man
    • May 2014
    • 3439
    I wouldn't use brake clean, I am not sure it's chemically compatible with and thus could damage valve stem seals, whatever pools in the head will dilute the oil too, it doesn't evaporate as quickly when mixed in with oil. If it's a layer of sludge remove what you can mechanically with shop towels and scrapers and use short OCIs with diesel oil or some other high detergent oil as necessary to clean things out with time.
    IG @turbovarg
    '91 318is, M20 turbo
    • e30davie
      • Apr 2016
      • 1788
      Being varnished like that is an indication of poor oil change intervals, but the varnish itself isn't a bit deal in my opinion. I wouldn't touch it. wipe out any actual sludge if it exists and just fill it back up with oil and change it regularly. Put the valve cover on and forget about it:)
      if you ever have the head off, get it cleaned at an engine machine shop in the hot degreaser cleaner. That's really the only way to properly clean a head.
      • Hoffbrohaus
        • Sep 2013
        • 519
        Perfect thanks guys. I was worried about the contamination, diluting oil. I'll just wipe off what I can.
        '90 325is
