KM steel rocker arms - M20
  • 82eye
    • Jan 2009
    • 2095
    Originally posted by hasa
    So you say that turbo engine can't live with properly chosen and shimmed valve springs and std rockers like N/A engines?
    You did not answer to my question, but anyway.
    sorry forgot this and skipped over.
    there's a set of heavier springs as well. i'd say there isn't a street car where the normal dual springs don't suffice. i would say the same for almost all turbo applications as well.
    my machinist told me there wasn't even a point to getting new ones for my purposes. we reused the old dual set, and just cleaned up the valves and seats. oh and a little street porting, no fancy.
    edit : colt cams suggested a heavier set paired with their turbo grind but i stayed n/a. even then, i'm not sure i could ever have reached the power needed for it, we don't have access to dynos or anything like that here.
    • digger
      • Nov 2005
      • 6182
      Originally posted by varg
      I don't see a compelling reason to upgrade the rockers when turbocharging unless you've increased cam profile aggressiveness or spring pressure significantly. A turbo doesn't necessarily stress them any more than being stock, it's only the abuse that usually comes with turbocharging. Think about the increases in forces involved; boost pushes down on the valves, exhaust stroke pressure on the face of the valve while open is negligible, increased heat doesn't reach the rockers. If you don't abuse your engine, (i.e. race use, drifting, bouncing off the rev limiter, revving past your power peak) I don't see them being an issue any more than stock. When I had ForcedFirebird rebuild my M20 head, he used resurfaced OEM rockers, I leaned on his spec E30/Chump car race experience to tell me that I was better off using inspected and surfaced OE rockers than buying IE HD. FWIW I have a 272° cam and my limiter is set to 6700rpm. I don't abuse my engine, I probably only hit the rev limiter a few times per month, I usually shift right at 6,500-6,600rpm if I rev it out.
      the force required to crack the exhaust valve open could be upto 300lb on a turbo engine which is alot more than the spring force even what you'd use with the RHD rockers. Many turbo engines get abused from what I've seen.
      IE HD definitely had issues but most seem to have been resolved e.g. pads falling off, short pads digging into the cam. In my mind there is a bit of a question mark about the surface finish of the pads but i haven't seen tonnes of people complaining about wear of late
      • bangn
        • Sep 2011
        • 760
        So couple of reasons for the want of an upgrade - Firstly my originals have done 340k kms and there is no surety they aren't fatigued, I had considered new OE replacements and shotpeening/polishing but Febi quality cannot be relied on as many know and there is a level of risk involved using them on a FI engine. Although I have a spare block, a head is really hard to come by now if something goes wrong. If something did happen that killed the head then it would mean a new AMC head ($2K plus port work to get it to 885 standard) or worse it makes a happy face in the piston if the cam locks up. I would like this engine to survive as long as possible.
        Id love to be able to communicate with IE about their rocker arms but they don't answer enquiries, I would hate to think what they're like if there was a warranty issue. Last time I tried to buy off them they canceled my order for being international and then I lost out on the exchange when money was returned.
        I desire to have an increased rpm limit to reduce lag going into the next gear. I guess there is a level of risk with all brands at the moment and its finding the set less risky.
        Boris - 89 E30 325i
        84- E30 323i
        • It's Soda Not Pop
          • Jan 2022
          • 877
          I have a head from Bimmerheads with the HD rockers. I've had this head since 2017. I've never had an issue with the rockers. IMO I rather have something overkill and never use than need it and not have it. But a lot people live by the if ain't broke don't fix it. Bimmerheads use these rockers in all of their head builds. I believe if a lot failures were happening they would have stopped using them by now. Also they are on this forum.
          88' Seta 2.7i Zinno
          https://www.r3vlimited.com/board/for...430-my-88-seta
          • digger
            • Nov 2005
            • 6182
            metric mechanic sell inspected and peened rockers so that's an option. I've been using them for 15years with almost 12mm lift and stiffer valve springs to 7000rpm and no snappage yet....touch wood
            • hasa
              • May 2013
              • 307
              I'll put all in to bet that your engine is fine as long as the "stiffer" valve springs are stiff. Not too stiff of course. PPF's turbo springs 65kg seat pressure sound hard to cope for other than billet rocker.
              • digger
                • Nov 2005
                • 6182
                if i recall when i had my head redone in 2008 the springs i used were Eibach, the shop measured the seat and force over nose of schrick springs and they were not happy with the 11.95mm lift cam so i got some springs from VAC (the Eibach's) and they were a measurable step up from schrick (a much bigger jump from schrick to Eibach than stock to schrick). These haven't been sold by VAC for years.
                i don't know who came up with such craziness in PPF spring choice but when you look at force over the nose, i'd be using steel rockers as a billet aluminium rocker may be at risk. The spring for RHD roller is like 80lb on seat and 280lb over nose and it was way way above that and totally unnecessary
                • bangn
                  • Sep 2011
                  • 760
                  So got pricing for the CAT022 catcams rocker arms if anyones searching to see what they're worth - 145€/piece which is 1740 euro a set plus freight. Bit more than i was anticipating, wouldn't be so bad if I lived in the states but Australian exchange rate kills it.
                  Im likely going to try out the KMs, if so il measure them up in the head compared to OE and see if theres any differences in lift at set degrees.
                  Boris - 89 E30 325i
                  84- E30 323i
                  • Northern
                    I like cupcakes & sh!tboxes
                    • 5276
                    At that price, I'd start thinking about the RHD roller rocker/cam setup. Already having springs makes it less attractive, but maybe you can sell to recoup costs on anything you already bought?
                    Originally posted by priapism
                    Originally posted by shameson
                    • bangn
                      • Sep 2011
                      • 760
                      So the steel rockers arrived, I put a rocker shaft in it and ran a 6mm stem through the adjuster hole onto both rockers to gauge how different they were in terms of rocker ratio/lift changes
                      Basically what I found is the centre of the pad is the same height and position as oem. KM Pad is a bit wider and a bit longer. I'm still going to measure them up in the head
                      so ive got some real data but I think any difference if any will be comparable to wear. At this point it seems the pad arc is comparable to OEM. Here's hoping the steel clamps the eccentric adjuster
                      with enough side load they don't move.
                      The KM rockers do sit a smidge looser on a new genuine rocker shaft, its not much but it does rock side to side a bit more than the brass bush type. Noticed a bit more noise audible
                      with steel against steel instead of the OEM bush when I spun it by hand. Hopefully they don't make a racket. All and all i'm pretty happy with the choice so far.
                      Click image for larger version  Name:	IMG20230621181603.jpg Views:	0 Size:	302.7 KB ID:	10097363
                      Click image for larger version  Name:	IMG20230621181551.jpg Views:	0 Size:	313.8 KB ID:	10097364 Click image for larger version  Name:	IMG20230621181533.jpg Views:	0 Size:	161.6 KB ID:	10097365
                      Click image for larger version  Name:	IMG20230621181503.jpg Views:	0 Size:	144.4 KB ID:	10097366​
                      Boris - 89 E30 325i
                      84- E30 323i
                      • Alouicious
                        • Jan 2025
                        • 1
                        I used them on a built '91 M20b25 with a Schrick 284/272, Schrick springs, oversized valves, new hardware, and new OEM rocker shafts. I had terrible valve noise and abnormal, triangular wear. Contacted Schrick with pictures, and they told me to check the rocker bore to shaft clearance- should be .002" - .004". Mine had like .009". Fortunately Bimmerheads gave me a refund on them.
                        • Kkyander
                          • Sep 2022
                          • 1
                          Assuming this was with the KM rockers? I was looking at getting a set myself as I’m building my head right now, what was your fix or did they send you another set as well? Being a new rocker shaft I’d imagine a used one will have more play.. TIA
                          • digger
                            • Nov 2005
                            • 6182
                            I would be giving these a miss unfortunately
                            • skitzy777
                              • Jul 2016
                              • 57
                              I was looking at these km rockers for my M20 though this thread has me thinking otherwise... Any other alternatives?
                              I'm running an Eaton m90 roots charger on my M20 at the moment and trying to select a camshaft too, would I be getting a cam that it geared towards a turbo setup?
                              -E30 323i 1983
                              -Honda CB250n 1980
                              • digger
                                • Nov 2005
                                • 6182
                                I am not aware of any other affordable steel rockers that exist. At one point Metric Mechanic were playing around based on their facebook posts but that was years ago precovid. you could ask them to see what eventuated. I have used their peened and inspected cast aluminum rockers for about 17 years without issue on a 7000 rpm engine with around 12mm lift and stiffer valve springs
                                i wouldn't be looking at a turbo cam with funky ex lobe, id look at a NA cam with LSA around 112
