Rough Idle- but not a surge?
  • e30details
    • Oct 2024
    • 6
    Hi everyone,
    I’ve done a lot of research on the forums on this topic. The ICV, AFM, timing belt, water pump, thermostat, throttle body boot, and seals
    have all been replaced. But the car still idles between .5 and 1k RPM. Any ideas?
  • It's Soda Not Pop
    • Jan 2022
    • 877
    Vacuum leak.
    88' Seta 2.7i Zinno
    https://www.r3vlimited.com/board/for...430-my-88-seta
    • It's Soda Not Pop
      • Jan 2022
      • 877
      Also did you buy a OE bosch ICV? or Chinese knock off?
      88' Seta 2.7i Zinno
      • 82eye
        • Jan 2009
        • 2108
        as above, however, i'd smoke it for a definitive leak test.
        edit : fyi the hamburg tech icv is hamburger tech in operation and has caused the same issue.
        • packratbimmer
          • Dec 2009
          • 1335
          How about the throttle switch?
          • DesertBMW
            • Aug 2011
            • 1043
            you don't even say what car you got, not all M20 have the same engine management, then how can someone help you when all you say you replaced bunch of parts and you got low idle, it could be anything.
            • e30davie
              • Apr 2016
              • 1788
              Can be anything!
              Do a compression test, maybe one of your valves are leaking........and if its not at least you'll know the condition of the engine.
              • Northern
                I like cupcakes & sh!tboxes
                • 5284
                smoke test that bitch
                Originally posted by priapism
                Originally posted by shameson
                • e30details
                  • Oct 2024
                  • 6
                  Thanks for the thoughts- I'll start with a smoke test...it's worse on cold start. It does a surge, then It almost dies and smells very rich in the garage. Once it warms up it's fine. the surging while cold is why I thought it was the ICV or AFM but with both of those replaced I'm stumped.
