ITB balancing
  • zaq123
    • Jul 2016
    • 1559
    ITB balancing
    I 've been putting some miles on the car with new tune and dialing idle as best as I possibly can. Decided to take of ITB plenum to check if the balance is still ok from what I initially set it at. I actually forgot that when I initially was balancing it, cyl 3 and 4 were off from each other slightly. Obviously RHD ITB can only be balanced in pairs. The only way to adjust is to mess with a throttle plate. However I recall Rama's instruction not to mess with plates as they are set to account for the expansion etc etc.
    Here is a video of it idling at 900rpm with Schrick 284 cam, my idle setting without AC (AC ON is 1000rpm). Cyl 2 and 3 TBs are off from each other by about 0.5-0.7 kgm or whatever this little tool shows? Should I leave it alone or mess with TB plate a little and hope it won't stick after?
    https://www.dropbox.com/scl/fi/zqa09f7gc1z9mz6wswe3z/ITB-balance.MOV?rlkey=fccfjmg7x98zad9i151h5dpjb&st=ulz iogbx&dl=0
  • zaq123
    • Jul 2016
    • 1559
    Post edits don't work again on this forum.. But just to add, my cam is Schrick 284...idles good enough for that cam?
    • digger
      • Nov 2005
      • 6177
      i only check balance with the ICV blocked off (and ideally cylinders unable to cross communicate via the small vacuum hoses), is the ICV operating in that video? Also presumably the valve lash has been done recent?
      Its a moot point but the more expensive throttle have a little bypass to tune throttles on the same pair but properly isolated they should be quite a bit closer than as measured
      • zaq123
        • Jul 2016
        • 1559
        valve lash was checked too many times due to me trying to stop that valve cover gasket seepage. It's not laking but sweats oil overtime just enough to annoy me. Originally syncd ITBs with ICV blocked of and at the throttle cable holding about 1000 rpm, ITBs idle screw is set to hold just over 800 rpm and ICV does the rest. This recheck was with ICV in the equation , just like in Ramas sync video.
        • digger
          • Nov 2005
          • 6177
          This whole thing is a rabbit hole
          i saw values of
          3.2
          2.8
          3.0
          2.2
          2.8
          2.7
          Your variation of 3 and 4 is quite off, with 4 running 27% less air than 3 which is not minor nor within normal tolerances. i dont think moving the blade will make up for this plus the screws can be a pita if locktited i always worry about stripping the little f...s
          Starting from the beginning there are a couple of things that must be correct to get good results overall
          1) The 3 manifolds needs to be perfectly co-planar (there is clearance to bolt holes so this is not a guarantee) ( a single manifold would have advantages here but a moot point and other issues.
          2) The throttle 3 shafts must be coaxial (there is clearance to bolt holes so this is not a guarantee)
          Any offset or angular misalignment of the shafts throws things off kinda like a universal joint. This is not likely the issue here but it is a good reminder
          When i test without any influence of the ICV i would typically expect to see the same reading on the pair almost bang on except maybe half the width of the indicator line. The machining is fine on the TB even my 12year old one still does good it shouldn't be that far out
          to me air is being ingested through the inlet valve this comes from both the throttle body and the vacuum tube from the ICV you are only measuring one path using that tool so not ideal. If you want to use the ICV then IMO you need to measure vacuum in runner to indicate total mass flow which presents its own issues and nuance i have been down there several times. i even retrofitted individual bleeds but waste of time just not worth the effort.
          i test at 1,000 and say 1,500 rpm and 2000 rpm to help understand any rpm variation, if it changes alot with rpm then 1) and 2) might be the culprit (never will be perfect as the engine is 6 individual cylinders/engines that are slightly different) and i favor around say 1500 as at idle the engine will happily idle with quite some variation as there is no significant load but 1,500/2000 rpm is a real driving situation.
          The same if i then hook the ICV up and it shifts/skews a bit because the hoses are different, the fittings are different or the little plenum is not big enough then i don't actually care as when the engine is doing some real work its more than likely going to be closer balanced geometrically at the throttle blades and the ICV air becomes a smaller % of the total ingested air.
          This is all just IMO though and there is always more than 1 way to skin a cat
          • zaq123
            • Jul 2016
            • 1559
            my understanding is that at WOT, this balancing error is really not that critical (unless of course it's a huge difference). But for good idle and off idle throttle response it is. I don't have any issues with throttle response but the idle is so so at 900rpm and definitely feels smoother at 1000. Although I think 900 rpm should be a realistic goal considering my camshaft isn't all that aggressive.
            All vacuum lines are the same length. Also cyl 3 runner vacuum port is also servicing the brake booster.
            • moatilliatta
              • 6152
              I've loosened and tightened the screws that hold in the throttle plate to help center the pates better. May help bring down a high number if you can then tighten that bank.
              Have you done a compression test too?
              those numbers don't really seem toooooo far off for only bank adjustments.
              @Zakspeed_US
              • zaq123
                • Jul 2016
                • 1559
                Rama said don't mess with plates so I took his word for it. No compression test yet, still putting miles on the engine to fully break it in.
                • Edrift
                  • Jun 2026
                  • 6
                  I'd leave it alone. A 0.5-0.7 difference at idle isn't enough for me to start touching throttle plates that were factory/set-builder calibrated. Rama's advice is solid—once you start moving individual plates, you risk introducing sticking, inconsistent closing, or needing to recalibrate everything again.
                  My rule is: if it runs great and the imbalance is minor, don't fix what isn't broken. I'd only consider touching the plate if there's a noticeable idle issue, vibration, or a cylinder clearly contributing less than the others
                  • digger
                    • Nov 2005
                    • 6177
                    I don't think there is anything wrong with the throttles but to be definitive you would need to test and isolate to see if they are both the same and inspect for wear if they are still out. In any case to properly set the position correctly you would want to be holding it in your hand so you can feel rubbing and drag as you rotate the shaft with your fingers and check for "light tight" as that is how they are set originally if you mess that up the blade will wear the ID of the bore and it will be out
                    • zaq123
                      • Jul 2016
                      • 1559
                      I spoke with Rama and have him watched the video. He said he can send me the throttle after the return but also he said that since I'm running vacuum, the difference I have is not that bad for the idle and operation. I hate to have the car out of service for a while, Rama is not exactly around the corner from me. But I guess I can alway buy it and return mine once I get/install new one. I assume that just the actual throttle blade section will fix it or I need the whore rnew runner from the head as well?
                      • digger
                        • Nov 2005
                        • 6177
                        i wouldn't be sending anything back at this point without further test and inspection
                        Without sounding like a broken record it would be useful to test just the throttle pairs without any vacuum at all for test purposes just cap or block the lines don't adjust anything with the linkage. There are 2 outcomes
                        - if you get the same result trend as you are currently getting then chance are barring some vacuum leak or something then it very well could be something with the throttles.
                        - If they both move the same amount of air within a reasonable tolerance then the throttles are good and it is something else.
                        based on the result there are more test that can be done
                        • zaq123
                          • Jul 2016
                          • 1559
                          Thank you digger. That's pretty easy to do. Also If I remember correctly when throttle pairs were in my hand, some had visibly noticeable plate to bore gaps (on sides of the plate shaft ) which looked different from each other to the eye. That prompted my question awhile back if I need to adjust those plates to have similar gaps but was told not to mess with it "as it was set from manufacturer for thermal expansion".
                          • TobyB
                            • 5286
                            My experience is from DCOEs on street and race cars, so it's not apples to applets, but...
                            when I got into that range for a race car, I usually called it good enough and then tuned by the EGTs.
                            Back then a wideband was expensive, so I only ran one in the collector, and it agreed that close only mattered at idle.
                            For street cars, on early carbs you filed/drilled/bent both plates and throttle shafts to balance the bores with each other.
                            I agree with Digger that trying to balance exactly with a UniSyn isn't going to be a precise science. If you can get
                            4 vacuum gauges on it at idle, THAT might, over time, give you a better sense of ... balance. Mechanically, that is.
                            Especially if you can watch all 4 ports at higher rpms with closed throttles on trailing throttle.
                            Eventually, with the carbs, I just did my best with idle mixture adjustments and mechanical tweaking of
                            the bores in the same body, and called it good enough. Especially since a lumpy idle was kinda sexy when I was younger.
                            Just what I experienced.... a long time ago.
                            t
