175whp
  • Fernflex
    • 264
    #61
    Im supposed to go tomorrow to the dyno, so I will post videos and graphics.
    Please Rate Me:
    http://www.r3vlimited.com/board/show...35#post3283535
    ________________
    1987 332i Track Car (253whp)
    __________________
    • Luis325
      • 3847
      #62
      Fern having fun at work????
      Love how the car runs man... LOL
      1986 "C2 2.7 Alpina" Sedan
      1987 325ic Black Vert
      • cheapshot
        • 451
        #63
        Originally posted by xwill112x
        I honestly can apprieciate a build like this, But its kinda dissapointing to see it only making what a stock m50 would :(
        Edit: with a good tune im sure youll gain some power, probably will be touching around 200ish horse
        So a 190 crank HP motor will put down 175 HP at the wheels? That's only an 8% loss if my figures are correct.
        • darvo
          • Dec 2010
          • 407
          #64
          A que hora vas?
          • Fernflex
            • 264
            #65
            Little preview, a rocker arm broke @7,500 rpm.
            I was only manage to get 180whp with the 19lb injectors @ 45psi, Im installing the 21lb injectors in the car.
            Please Rate Me:
            ________________
            __________________
            • darvo
              • Dec 2010
              • 407
              #66
              Will you replace it and keep tuning it today?
              *Time for HD rockers!!
              • JJe30
                • 2044
                #67
                Very nice build.
                • Fernflex
                  • 264
                  #68
                  Tomorrow they will replaces all rocker arms and installe the new heavy duty with the bigger injector and going to wait for the wasted spark to arrive to go back to the dyno.
                  Darvo: sorry I didnt call you, my mech planned everything and he didn't told me until the last moment.
                  Please Rate Me:
                  ________________
                  __________________
                  • digger
                    • Nov 2005
                    • 6207
                    #69
                    so it broke at 7500rpm or afterwards?
                    can you snap some macro shots of the fracture face?
                    • ForcedFirebird
                      • Feb 2007
                      • 8300
                      #70
                      You ran the stock single coil over 7500RPM? Bet it was real happy with that lol.
                      john@m20guru.com
                      Links:
                      • darvo
                        • Dec 2010
                        • 407
                        #71
                        No prob!
                        • Fernflex
                          • 264
                          #72
                          Ebay Headers, Big Valves, Itbs kit.
                          HD Rocker Arms
                          Please Rate Me:
                          ________________
                          __________________
                          • Fernflex
                            • 264
                            #73
                            Stock
                            HD
                            Please Rate Me:
                            ________________
                            __________________
                            • digger
                              • Nov 2005
                              • 6207
                              #74
                              i cant see 100% but in this particular case that looks like overload failure rather than a small crack propogated by fatigue which sunsequently grew to a size that caused catastrophic failure. This goes away to confirm that valve bounce could be the main factor factor which while an obvious conclusion it shows that peening is not a huge benefit against this mode of failure. The casting quality seems inferior to the original BMW rockers i have with me but it may just be the pics. The MM testing showed some rockers were 30% stronger in a single static test.
                              • Stephen
                                Шлем ишака
                                • 10774
                                #75
                                Awesome to see a diy ITB setup done through to the end. Jealous.
