175whp
  • Fernflex
    • 264
    #31
    update
    Please Rate Me:
    http://www.r3vlimited.com/board/show...35#post3283535
    ________________
    1987 332i Track Car (253whp)
    __________________
    • ROLLingKING
      • Apr 2011
      • 1169
      #32
      Originally posted by Fernflex
      I also need an adjustable fuel pressure regulator, what are the best options?
      ditto
      m20 is plenty. im simply a drifter.
      build thread -- http://www.r3vlimited.com/board/showthread.php?t=206510
        • 34847
        #33
        if you have MS or the ability to tune, you don't need an AFPR.
        • whodwho
          • Jun 2008
          • 1547
          #34
          Unless you are trying to cheat and using smaller injectors that are maxed out :)
          My M20 Frankenbuild(s)
          4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
          • ROLLingKING
            • Apr 2011
            • 1169
            #35
            ooh true. thanks man
            • ROLLingKING
              • Apr 2011
              • 1169
              #36
              Im waiting for the megasquirt to remover the afm and install a set of itbs.
              My bbtb I got it from a friend who bought it form Gruten parts you can also buy it here. http://www.westcoastriots.com/htmlfiles/Products.html
              them ITbB's look baad ass. im not trying to hijack this thread or anything but did u notice any differences after swapping to a bigger throttle body. It seems you know what your doing and can maybe help me understand its benefits. ive been told a few times on r3v and just shooting the breeze with friends that they dont do anything to a m20. Since YOU HAVE ACTUALLY DONE IT how do u like it? I am very interested in getting the larger throttle body for a turbo M20. and did u need an adapter to fit your manifold?lol
              if youd like u can PM me back. nice work tho!
              • reztat
                • Dec 2010
                • 72
                #37
                I likes this thread so much!, I wanna to meet you sometime, I live in Arecibo! Your car is sick, Im interested in the setup because mine is an SETA...
                • e dub
                  • 212
                  #38
                  Any updates on this? I'm really interested in seeing how the itb's worked out?
                  • 5Toes
                    • 9836
                    #39
                    Originally posted by Luis325
                    Engine is a stroker with Eta crank and rods with i pistons with notched valve reliefs and cut piston skirts. Decked block.
                    I head ported and polished with Schrick 288 cam with 1mm oversized eccentrics from IE.
                    Big bore TB. 17.5 injectors. Running on stock motronic 1.3.
                    Long tube Headers and crappy exhaust... ( lol fern has a double 2.25 from the headers to 2 18" bullet resonators an then a 22" dual in/out magnaflo...)
                    Trying to get him to change to a single 2.5 with just a borla or vibrant muffler! (do it)!
                    Im surprised hes making good power with all the mods untuned and having the car lean out after 5,000 rpm. Redline is stock 6,900 .
                    When MS is tuned and ITB's are on common 7,500rpm sexy time!
                    Compression is gustimated a 10.1
                    So compression is higher than normal because block has a mm or 2 off??
                    • digger
                      • Nov 2005
                      • 6207
                      #40
                      my guess would be that when you add 3mm of crank throw and take 5mm off the rod you are 2mm down the bore. Deck the block to get the piston back to where it was and the CR goes up from nominally 8.8:1 to 9.42:1. A little skim off the head and it goes a bit higher again.
                      This is the cheapest way to do a pretty good stroker as you get the extra CC, bump in CR and retain the squish. All you need is a hotter cam to help the topend and with the I intake, I electronics, I exhaust and you'll make more power than an I accross the board unlike the other budget strokers which are not worth the effort IMO
                      • Fernflex
                        • 264
                        #41
                        Update
                        New video with itbs installed, I haven't tuned the Megasquirt yet the car still start's like stocks
                        Thanks to blueapplesoda and Csi Motorsports.
                        Please Rate Me:
                        ________________
                        __________________
                        • Fernflex
                          • 264
                          #42
                          The car is not dyno tuned yet!
                          Please Rate Me:
                          ________________
                          __________________
                          • Wh33lhop
                            • 11705
                            #43
                            paint sucks
                            • e30trooper
                              • 11576
                              #44
                              Wow
                              • Killacortes
                                • 1937
                                #45
                                Those are serious number man! Glad to see a 2.7i with higher CR
                                r3v does not fuck around. First you get banned, then they shoot you
