M20b23 crank In a stroker? Can I?
    • 34844
    #31
    This is the worst stroker thread i've seen in recent memory.
    OP, you should listen to people who've built a few of these motors. What you are trying to build is not going to get you what you think it will. The B23 crank is a waste of time.
    • 2mAn
      Señior Mod
      • 21005
      #32
      Originally posted by digger
      m52 crank will yield much better results. peerless on e30tech did this b23 crank a few years back. the engine never really made anymore power than the B25 motor and same with torque from what i remember. there is any value in the effort IMO unless you have a displacement rule for a race class.
      my friend currently owns the car that peerless built. made ~135whp without a tune then jumped to around 160whp and about 170ft/lbs with the Miller MAF conversion.
      Simon
      Current Cars:
      -1966 Blue Boat
      -1969 Red VW
      -1986 White BMW
      -2006 Green Thing
      Make R3V Great Again -2020
      • digger
        • Nov 2005
        • 6195
        #33
        and look what fresh B25 engines make i.e. 150-155 whp on AFM and motronic...so like i said its a small gain over a standard B25 when rebuilt the same level of detail. for not much more effort or cost you could have a B28
          • 34844
          #34
          exactly what digger is getting at. that's basically what you'd get from a similarily prepped B25. a B28 would have lots more potential for basically the same effort. and honestly a 3 liter doesn't cost all that much more..
          • Pdxseth
            • May 2012
            • 3124
            #35
            Well I do have everything for a 2.7 i maybe I'll just stick with my original plan...... :(
            • Wanganstyle
              • 2828
              #36
              M20b25
              Fresh stock head stock cam; stock springs and rockers
              Bottom end 200k miles +100 hours of racing
              91 octane cali pump poopgas
              Stock computer and airflow meter
              Turner chip
              Dyno'ed 154rwhp right after an enduro.
              • 2mAn
                Señior Mod
                • 21005
                #37
                Im not saying its better, Im simply telling you guys what his setup made. He was planning another build M20 build with a M52 crank ;)
                Simon
                Current Cars:
                -1966 Blue Boat
                -1969 Red VW
                -1986 White BMW
                -2006 Green Thing
                • redlightpete
                  • Mar 2012
                  • 265
                  #38
                  Originally posted by Pdxseth
                  All this math is too much for me. I've read the build thread on e30tech over and over again. I've learned a lot today.
                  It works
                  885 head
                  323 cam
                  M20b25 pistons
                  135mm rods
                  M20b23 crank
                  And a .098" mls head gasket will leave plenty of clearance
                  A better plan would be:
                  885 head
                  M20b25 pistons
                  130 mm rods
                  M20b27 crank
                  stock head gasket
                  Deck the block to the desired compression ratio
                  You can probably get the block decked for about the same cost as the mls head gasket. You'd have a bigger motor and more flexibility with the compression ratio.
                  • digger
                    • Nov 2005
                    • 6195
                    #39
                    885 head
                    M20b25 pistons
                    130 mm rods
                    M20b27 crank
                    stock head gasket
                    better to use b28 crank dont need to take 2mm off only 0.5mm and more cubes
                    • Pdxseth
                      • May 2012
                      • 3124
                      #40
                      I'm just going to go with what what people have done it's easy to get a tune for a 2.7i
                      885 head (with port/valve work)
                      130mm rods
                      Seta pistons
                      Eta crank
                      And a 274 cam
                      (I also have headers, port matched intake, p&p'd tb and an m30 afm.
