copper HG spray...Anyone use it?
  • volvolover
    • Jan 2014
    • 89
    I'm having my HG replaced later this week by a reputable mechanic and I DON"T want to be doing this job again in a year or two!
    Any good reviwes? I have the VR HG set, but I'm using a BMW OEM HG for the install.
    thanks in advance
  • digger
    • Nov 2005
    • 6127
    thanks in advance
    ive not used it and dont think its neccesary for a stock gasket. last time i did a HG i used a Goetze, and time before that a BMW dealer unit no problems with both
    • Bearmw
      • 1323
      No but have used it on exhaust gaskets a lot.
      • acolella76
        • 2950
        It's unnecessary unless you're using a MLS gasket, and even then it still doesn't really work that well (at least in my experiences)
        -Alex
        • jeffnhiscars
          • Jun 2011
          • 6011
          I used some on my Elring HG, which i believe is OE, and after 16k I forgot its there (thats a good thing)
          Alice the Time Capsule
            No sort of sealant is needed, or helpful, if the head and block are flat and clean. Of equal importance is chasing and cleaning the threads in the block. Well, and using new head bolts.
            • nomansland92
              • 1657
              I used it when I did my head gasket, had no problems with it.
              IX being restored here
              Ix turbo build here
              • ttrousdell
                • Nov 2009
                • 1770
                Many recommend the copper spray for the MLS gasket. MLS doesnt recommend it and I have not used it on my MLS gaskets and have had no problems. Also with stock gaskets i have used sealant and also not used sealant and had no issues. As stated the best way to provide a good sealing surface it so make sure the head and block surfaces are are flat and clean as possible.
                The Build:
                • StereoInstaller1
                  GAS
                  • 22679
                  thanks in advance
                  First, check that OE headgasket: if it says Victor/Reinz, take it back. As far as I know, the real OE gasket has been gone for years. Goetz is a great choice IMO, I have yet to have any failures at all.
                  Second, BMW wants it installed dry, I would not use copper spray. This isn't a chebby, don't use chebby tricks on BMWs.
                  Fresh stretch bolts and a good gasket generally last 20 years or more.
                  If I were you, I would also do fresh intake manifold gaskets, new throttle body gaskets and a couple of others I can't remember right now that don't come with the set. Oh yeah, hot water passage on the TB too, those always crap out after only 25 years or so.
                  Best of luck, go kick its ass!
                  Luke
                  Closing SOON!
                  Thanks for 10 years of fun!
                  • dougie30
                    • Apr 2012
                    • 1708
                    I have it works great. My engine block was pitted from corrosion so I used some of that on the goetze hg and it hasnt leaked sence
                    Sent from my SPH-L710 using Tapatalk
                    M30 is God's motor.....but Jesus drives an M60'd car -slammin.e28
                    • 603Racing
                      • Dec 2010
                      • 612
                      I would say that it probably won't hurt anything. It may not help anything either, but there's a chance it might. That being said, when I replace my head gasket in the next few weeks I will use it. I will also NOT be using a Victor Reinz head gasket.
                      Take note of the quote in my signature. :)
                      90 325i DD/Track
                      03 Durango 5.9
                      Originally posted by e30mpg
                      It is recommended to get new gasket but this is R3v and we just copper spray that shit......slap biotch on and tighten to tq.
                        • 34839
                        I use it all the time. never had a problem. what it really seems to help with is keeping the gasket stuck to the surface while you fit everything together and tighten it down.
                        • Wanganstyle
                          • 2828
                          I've seen VR head gaskets hold 1krwhp. And work fine for years on a few of my cars
                          Copper spray I've used a few times; it's good to make gasket assured not move.
                          Sent from my SAMSUNG-SGH-I337 using Tapatalk
                          • efficient
                            • Feb 2012
                            • 3312
                            Mine has it on. No leaks don't see what it could hurt.
