Are These Rods Good?
  • digger
    • Nov 2005
    • 6198
    i've heard of guys measuring to a tenth for bearings on one of the HPF videos. i don't have the right equipment to know if this is realistic and repeatable in practice.
    • EatsHondas
      • Sep 2012
      • 404
      Originally posted by nando
      .0001, you can't even measure that accuratley. Thermal growth from holding the mic in your hand is probably more than that.
      Aircraft parts are often to .001 or maybe .0005 at most...
      M20 connecting rod specifications run out to 4 decimal places in the Bentley (with a tolerance of +/- .0002 being common), are you saying you can just throw out the last decimal for all rebuild/tolerance checking procedures? If that's true, it's news to me.
      1989 325i Lachssilber Sedan
      5-Speed Swapped
      M30B35 Swapped
      MegaSquirt MS3X
      1987 325i Lachssilber Sedan
      260k OEM Automatic Daily Baby
      • EatsHondas
        • Sep 2012
        • 404
        http://www.mscdirect.com/product/det...&item=57480824
        Guess it depends how much you're willing to spend. But the tools are out there.
        5-Speed Swapped
        M30B35 Swapped
        MegaSquirt MS3X
        • AndrewBird
          The Mad Scientist
          • 11898
          A dial or micrometer bore gauge can measure down to tenths no problem. Some can even measure down to .00001, but those are rarer and more specialized.
          Pretty much any bore for a bearing will have at least a +/- .0005 tolerance. All depends on the application.
          • LJ851
            • 7919
            You don't throw out the fourth decimal place (in inches), it's just that ONE tenth is not really going to make a difference. A few tenths, yes in a few select parts on an engine. Crank journal taper and roundness for example.
            Lorin
            The M30 is God's engine.
            • TobyB
              • 5296
              ...and a .001 graduated mic can feel the difference of .0001 in the crank, certainly...
              t
