Are These Rods Good?
  • stanhayward
    • Mar 2013
    • 765
    http://www.ebay.ca/itm/BMW-M20-325e-...vxp=mtr&_uhb=1
    Does anyone have experience with these? Balanced to within a gram (apparently) and ARP 2000 bolts? Seems like a killer deal if they're actually well made...
    1990 325i Touring - The Bonsai Bimmer - Patiently Waiting
    1984 316 Coupe - The Base Model - Pain in the Ass
    1988 750iL - The Daily Driver
    ...And a couple others...
    • 34839
    are you sure you want 130mm rods?
    • stanhayward
      • Mar 2013
      • 765
      Yup, I am putting together a budget stroker with an M52 crank, 130mm rods and stock i pistons and 0.5mm decked off the block. I know the rod length is too short for the best performance, but for right now this is all I need.
      • Cayoncrusier93
        • Jan 2013
        • 204
        I have NOT used them but from reading the description, "made from 2 separate Pieces for stronger strength" what is that suppose to mean? Seems weird, i would think they are cast in one piece?
        • stanhayward
          • Mar 2013
          • 765
          It seems too good to be true honestly, especially with a lifetime warranty too... I may just have the stock b27 rods I have balanced and but some ARP rod bolts for them....
          • TobyB
            • 5263
            Seems like they spend more time marketting the bolts than the rods-
            I'd find some decent OEM rods, buy the good bolts, and be done.
            Because BMW did NOT use Chinese made rods of unknown quality back then...
            t
            • digger
              • Nov 2005
              • 6132
              the issue will be a big end / pin size accuracy on a low hp application. the material wont be the limiting factor. eta rods are alot cheaper and go with the budget theme
              • redlightpete
                • Mar 2012
                • 264
                Try to get some with good pin bushings to avoid having to get replacemant ones sized.
                • EatsHondas
                  • Sep 2012
                  • 404
                  Balanced within a gram? Is that supposed to be impressive? A blind kid could do that with a whetstone. Precision internals are supposed to be measured to within .0001 (ten-thousandths) of an inch and at least hundredths of a gram if not smaller. I would stay away from these rods.
                  1989 325i Lachssilber Sedan
                  5-Speed Swapped
                  M30B35 Swapped
                  MegaSquirt MS3X
                  1987 325i Lachssilber Sedan
                  260k OEM Automatic Daily Baby
                  • digger
                    • Nov 2005
                    • 6132
                    hundredths of a gram lol
                    • EatsHondas
                      • Sep 2012
                      • 404
                      Am I wrong?
                      5-Speed Swapped
                      M30B35 Swapped
                      MegaSquirt MS3X
                      • digger
                        • Nov 2005
                        • 6132
                        Am I wrong?
                        a tenth of a gram is more than enough, any less than that and i think people are exaggerating the accuracy of the scale in a 500g part.
                        1 tenth is 0.1g, so this in 500g is 1 part in 5,000 or 0.02%
                        1 hundredth 0.01g, so this in 500g is 1 part in 50,000 or 0.002%
                        • LJ851
                          • 7919
                          LOL, one ten thousandth.
                          Lorin
                          The M30 is God's engine.
                            • 34839
                            .0001, you can't even measure that accuratley. Thermal growth from holding the mic in your hand is probably more than that.
                            Aircraft parts are often to .001 or maybe .0005 at most...
                            • SkiFree
                              • Jun 2011
                              • 2766
                              and to understand the weight of a gram in practical terms...... it's about the weight of a single sheet of copy paper.
                              And for the record, these rods are not balanced even close to the advertised amount. As all China parts, it's always hit or miss to start with. The only saving grace is the diligence of the middle man (I wouldn't say a ebay store middle-man is all that diligent). It took 3-4 sets to put together a decently "balanced" set.
                              ADAMS Autosport
