M43 valves in M20 head
  • abit
    • Jul 2011
    • 422
    #31
    ok, this mod is done, today was first drive with my fresly built engine, seems like its working fine :)
    so... made spacers for valve springs (1,4mm), @ start
    after some while :D
    also valve stems were shortened, actually, talked about that with one local engine builder, he actually told that I maybe could not shorten them, because rocker eccentrics would compensate valve length, buuut then I checked this theory, and reality is that you just can't install rockers at all, becouse they wont slide on valve :D so removed 1,3mm
    and there all together
    http://instagram.com/mundieriss
    my 88' m20b30 HERE!
    • Ether-D
      • Sep 2011
      • 2838
      #32
      Cool bro. Keep us updated. Good job.
      Originally posted by Andy.B
      I was born on 3/25…
      • downforce22
        • Aug 2009
        • 3192
        #33
        Its neat to see this done, but I don't see the value in all of this work? You add spacers which is more weight to lose 13 grams per valve.
          • 34844
          #34
          the spacers are on the bottom, they don't add to the valvetrain mass.
          • abit
            • Jul 2011
            • 422
            #35
            wait, what? how these spacers can add moving mass for valve/spring if its at the bottom and does nothing to that :D
            also modifying these valves and spacers was cheap as fck and easy to install, so why not?
            my 88' m20b30 HERE!
            • abit
              • Jul 2011
              • 422
              #36
              recently dyno'ed engine, don't know if these valves helped to gain more or even lose power :D but result is like this... about 6500 km's driven and all still looks good :)
              my 88' m20b30 HERE!
              • mr2peak
                • 2388
                #37
                Anyone else do this?
                Drive it hard. Maintain it well.
                A Topless Memorandum
                • abit
                  • Jul 2011
                  • 422
                  #38
                  I belive no :D
                  my 88' m20b30 HERE!
                  • redlightpete
                    • Mar 2012
                    • 265
                    #39
                    That's a pretty solid power number. What cam is that?
                    • digger
                      • Nov 2005
                      • 6178
                      #40
                      Dont forget this a euro dyno so crank estimation. Hp at wheel is 160
                      • abit
                        • Jul 2011
                        • 422
                        #41
                        Jep, these are numbers on engine. But still, I think It's pretty ok for m20b28.
                        I will try to make some minor changes in exhaust/ adjustable cam sprocket, maybe engine will become more funny as It is :D
                        my 88' m20b30 HERE!
                        • digger
                          • Nov 2005
                          • 6178
                          #42
                          catcams seem to like some advance, i think they must have wide LCA and so need it to build some dynamic comrpession
                          • abit
                            • Jul 2011
                            • 422
                            #43
                            so the update that no one asked for
                            it turned out that my 885 head has a crack
                            so, the head was removed and when disassembling the cylinder head, a not very good view was revealed..
                            so 11 years and about 40k kilometers (24854 mls)
                            a nasty view was revealed, three of the 6 valves had damage to the stem ends.
                            one only had a few craters, the other the same but the end was slightly flattened, and one valve was completely flattened
                            it looks like the non-original valves were not all hardened deep enough, or different depths, a quality problem?
                            plus I don't know if it's related to that, but the intake guides are all very worn out.
                            but yes, 3 valves are without any damage!
                            this is the worst one
                            maybe if I had used the BMW original m43 valves this wouldn't have happened, I don't know, but in any case the question about the valve guides remains unanswered
                            and.. I already bought these as for intake and for exhaust
                            my 88' m20b30 HERE!
                            • digger
                              • Nov 2005
                              • 6178
                              #44
                              the guides could be more worn due to the original geometry change from the different length or the fact that they wore axially which then resulted in more side loading or some other aspect of the stem to guide clearance was off unrelated to the original geometry change
