What oil do you run???
    • 34847
    I ran 15W50 mobil 1 for years. I like their turbo diesel truck oil - I think it might be a 5W40 or something. Works it a little less hard when the engine is cold, but still has like 1100ppm of ZDDP. I'd still run the 15W50 on hot summer track days though. It was fun being N/A, all those super fast turbo cars would die off like flies but the N/A cars could go all day if their oil could handle it..
    I haven't changed the oil in the E90 yet because the computer still says I have another 6k left. :???:
    • ForcedFirebird
      • Feb 2007
      • 8300
      Originally posted by nando
      i haven't changed the oil in the e90 yet because the computer still says i have another 6k left. :???:
      ha!
      john@m20guru.com
      Links:
      • turbo55
        • Jul 2014
        • 223
        15w-50 Mobil 1, comes in a 5 L jug at walmart.
        Oddly enough, other than Mobil 1, I couldn't find any other 15w-50 at all at my local stores. Plenty of 15w-40 variety though, but the 15w-50 has a wider range of temps so I'd rather get that as it gets above 80F around here in the summer.
        • ELVA164
          • 4861
          Originally posted by e30onBBSs
          Look in the back of the owners manual, it has a chart of the oil you should use based on the temperatures you have.
          This needs to stop being referenced. That book is 30 years old, back from the age where synthetics were brand new technology. It does not accurately apply anymore. It's good for a general idea.
          • digger
            • Nov 2005
            • 6199
            10W-50 ULX110 which is a local brand ive swapped to based on feedback from some good sources
            previously i used 10W-50 penrite
            i like a 10W as it flows a little better when cold than 15W or 20W which i have used before
            50 seems to give me the right idle oil pressure when the oil is 200F or so, at higher rpm the oil pressure is good to
            • e30onBBSs
              • Dec 2014
              • 1347
              Whats changed about the weights? The technology has changed but if we put 15w50 from back then and ran them side by side would there be a difference? In the long run there would be obviously, but for 5 minutes? You are probably right, I barely know anything about oil but it seems like the temperature tolerances wouldn't change with time?
              BMW tech
              Umass Amherst
              05 wrx sti
              • modernist
                • Apr 2014
                • 283
                20W50 dino oil all year, in Ohio. No problems starting in the cold. Generally don't use the car when temps drop below 10°.
                1986 327i
                transaction feedback
                DIY thing
                meh
                • ForcedFirebird
                  • Feb 2007
                  • 8300
                  The weights haven't changed so much, but back then there was a lot of ZDDP in oils. Newer catalyst technologies require low ZDDP oils, so it was eventually phased out almost entirely.
                  john@m20guru.com
                  Links:
                  • estoguy
                    • May 2013
                    • 1087
                    I've been using Castrol Edge 5w50 for the last two years. No complaints or issues. I run it all year long up here in Ontario.
                    Estoguy
