Timing Belt ... How urgent?
  • rturbo 930
    • Dec 2005
    • 2621
    Isn't 5 years/50k miles the timing belt change interval? That's actually kind of scary that the belt could still snap within, or just outside of the 5 year interval. I would think BMW would engineer in a bit more wiggle room than that. Could it just be a bad belt?
    • ForcedFirebird
      • Feb 2007
      • 8300
      There are many factors for the belt degradation. All the "broken" belts I've dealt with had problems with the cogs ripping off, not the belt actually snapping.
      john@m20guru.com
      Links:
      • packratbimmer
        • Dec 2009
        • 1335
        Anyone have experience with the Gates racing belt? Curious about them...
        • 330SMG
          • Feb 2007
          • 172
          The difference with the BMW belt system is a non adjustable tensioner. So as the belt stretches there is no compensation. Plus the water pump is buried below the timing belt and I would do the job just to change that, since if that fails you are dead in the water(unintentionally pun).
          1989 Cirrus Blau coupe Racing Dynamics wheels and a Volvo Spoiler.
          • kye
            • Dec 2013
            • 217
            Originally posted by AndrewBird
            ^^^Do that and see. If there are any cracks in the teeth or cords showing, don't drive it, but if it looks new, I wouldn't hesitate to drive it.
            2000 KM really isn't that far. If he says it's been done, I wouldn't worry. Does he have any paperwork showing it's been done?
            I just changed mine after having the motor for 5 years unknown how long before that it was changed. Plus it gets pretty hot and pretty cold here and i haven't drove more than 1200 miles in that time.
            My old belt looked just like my new one.
            • TobyB
              • 5268
              I got a parts car in 2011 with a chowed belt and trashed head. The idler had failed,
              and the belt wandered off and shredded. A lot.
              It had exactly 160k on it. The belt had been changed in 1998, at 58k.
              So THAT belt lasted 102k and 13 years.
              Your mileage will vary.
              Me, I'd drive it if it was a year over and I had some reason to be lazy, as in, "it's only got 20k on it".
              But I don't mind changing cylinder heads, either.
              t
              • Ether-D
                • Sep 2011
                • 2838
                Listen to it. If its making any funny rubbing noises, don't drive it home. But if it sounds ok, I say drive it home. It'll be fine. You'll be cruising at 2500rpm most of the way. Then just change it yourself when you're home.
                Originally posted by Andy.B
                I was born on 3/25…
