M20 2.9L Stroker Recap
  • efficient
    • Feb 2012
    • 3312
    You did all the work in a apartment parking lot?
    • Reichart12
      • Aug 2012
      • 2165
      A shop put the rotating bottom end in the block and Bimmerheads took care of the head. I assembled the rest of the motor in my dining room and swapped it in the front parking lot. Its a townhouse court so maybe a little more easy than an apartment. And the exhaust was done at another shop.
      Instagram: Reichart12
      • ForcedFirebird
        • Feb 2007
        • 8300
        Digger is right. I have obtained 223whp from 17lb injectors with hardly any increase in fueling over stock (413 dme on an s52). On another modified s52 I was able to get over 240whp on 24lb injectors.
        Also, don't pay attention to the stock spec for the CPS. On the MS installs I have done, it likes the crank sensor closer factory spec. I tend to just get as close as I can without rubbing and have had good success with it.
        john@m20guru.com
        Links:
        • Northern
          I like cupcakes & sh!tboxes
          • 5251
          I assume you used the 3bar "i" FPR, but if you had an eta 2.5bar one, it might explain why you're running out of fuel with those pinktops. They should still be like 20lb/hr @ 3bar, and 18ish at 2.5bar. That sounds like enough to me, but maybe it isn't?
          Originally posted by priapism
          Originally posted by shameson
          • Reichart12
            • Aug 2012
            • 2165
            Yup, doubled checked and I do have a 3.0 bar fpr installed. Came with the engine. Maybe moving the CPS closer could help and the break up in the graph was more a problem of this than fuel. I'll have to plug my laptop in and see how the settings and logs turn out.
            • digger
              • Nov 2005
              • 6169
              would be nice to see an AFR trace, probably first step is to get that and see if what youre been told is true then start going through fuel system perhaps
              • Reichart12
                • Aug 2012
                • 2165
                A couple of copy and pasted posts from my members ride thread. I'm getting closer to 200!
                Following ForcedFirebird's advice...
                Turns out the breakup in the dyno graph was caused by the CPS being too far away. Stock spec does not cut it, I moved it closer and the car revs powerfully up to 7300!!!!! Unsure if I would still need larger injectors but this change with the CPS made a huge difference and the car is even that much more wild to drive.
                And then because I couldn't resist...
                The local Pepboys had a dyno at their car show today so I figured why not toss the car on it. I told the guy to take it to 6800-7000 but he let off at 5000 because he said it felt weird. Watching it from the side, it sounded normal and driving home it had no problem going to 7k so I don't know what was up with him. Anyways I scanned and uploaded the graph...
                192hp with 202ft/lb lifting at 5000 rpms!
                I know I still need to get an AFR trace of it and Im dragging my feet to keep moving with it but I feel good to have found the solution to one problem. More to come hopefully sooner than later.
                • ForcedFirebird
                  • Feb 2007
                  • 8300
                  Glad to help, and nice power!
                  john@m20guru.com
                  Links:
                  • darvo
                    • Dec 2010
                    • 407
                    In for videos
                    • 2mAn
                      SeƱior Mod
                      • 20883
                      Originally posted by digger
                      U shouldn't be running out of fuel with 21lbers
                      thats exactly what I was thinking. My M52 uses the pink injectors and I put down 225whp. Im glad that didnt turn out to be the issue and Im really excited to see what this will put down at 6000rpms
                      Simon
                      Current Cars:
                      -1966 Lotus Elan
                      -1986 German Car
                      -2006 Volkswagen Jetta TDI
                      Make R3V Great Again -2020
                      • digger
                        • Nov 2005
                        • 6169
                        still looks like some sort of ignition issue at the topend IMO
                        • crappycoco
                          • May 2014
                          • 250
                          How can you see that from that graph? Is it because it gets a bit erratic?
                          • digger
                            • Nov 2005
                            • 6169
                            just looks to get more erratic at the very topend, maybe its normal with zero smoothing though?
                            • iwantspeed
                              • 3164
                              Nice. Power
                              Project
                              Parts for Sale
                              Feedback
                              YouTube Channel
                              • SNEAK413
                                • 33
                                Are the electrics new? Cap, rotor, wires, coil?
                                Also sent you a pm
