Das Beast: My E30 track / street build
  • dvallis
    • Oct 2015
    • 1474
    #871
    Highest temp heatshrink I could find was only 300F. Where can you get a higher rated one?
    "And then we broke the car. Again." Mark Donohue, "The Unfair Advantage"
    1987 E30 3L Turbo Stroker Das Beast
    2002 E39 M5
    • Digitalwave
      is a poseur
      • 6293
      #872
      Originally posted by zaq123
      I was more looking into the routing, not termination. Didn't realize you are using innovateM setup. I'm using 3rd party lamda controller that's built into the motronic ECU adapter board for MS2. Figuring out the best way to attach LSU4.2 lamda connector somewhere so it looks "factory".
      I just zip tied mine under the front battery tray. The wires are routed through the tranny tunnel/firewall. There are little wire hangers on the stock heat shielding, probably for the stock reverse switch?
      dvallis, you're working with Motronic stuff, not Motec :D
      RISING EDGE
      • dvallis
        • Oct 2015
        • 1474
        #873
        LoL. Yes, Motronic. I was tired. :-)
        2002 E39 M5
        • kronus
          • Apr 2008
          • 13032
          #874
          TE HT-200 goes to 400
          your plastic injector connectors don't though
          cars beep boop
          • dvallis
            • Oct 2015
            • 1474
            #875
            LoL. If they are melting the car is on fire and its time to bail out anyway.
            2002 E39 M5
            • dvallis
              • Oct 2015
              • 1474
              #876
              Built the harnesses for fuel and oil pressure sensors. There are two on each: one for the gauge and one for the data acquisition system. Those are the only two pieces of vital engine data I can't get from the ECU CAN stream.
              Oil sensors will be relocated away from the turbo and oil block by a 4AN braided stainless hose with 1/8"-NPT Tee fitting on the end. We will be able to mount the sensors on or near the firewall, outboard of engine harness and coils. Fuel sensors Tee off the pressure regulator gauge port.
              2002 E39 M5
              • moatilliatta
                • 6144
                #877
                Dr-25 is good, Id just make sure its flame retardant.
                @Zakspeed_US
                • dvallis
                  • Oct 2015
                  • 1474
                  #878
                  Back from vacation and work travel. Updating thread tomorrow.
                  2002 E39 M5
                  • dvallis
                    • Oct 2015
                    • 1474
                    #879
                    The Beast is Back
                    Alright, back from vacation, work etc. We're working on engine bay accessory wiring harness. It powers everything besides the engine: Running lights, turn signals, horns, headlights and fans.
                    Here we are testing the LED headlights. They are 5-1/4" and will drop into the E30 trim.
                    This is a 1A fuse, lit up. A 2A fuse didn't even break a sweat, so we guess the lights pull about 1.5A. Somewhat better than the ~5A a stock headlight draws.
                    Here's the driver side business end of the aux harness: headlights, run lights, turn lights and horn. Fans splice out of the passenger side.
                    We ran the harness inside the upper rail of the front clip. Wanted the "invisible wiring" look.
                    Here's where it comes out on the passenger side. We'll have another splice there before it dives back inside the body work and runs to the cabin.
                    That's all for now. Wiring takes a lot of time. :devil: LOL
                    2002 E39 M5
                    • dvallis
                      • Oct 2015
                      • 1474
                      #880
                      Passenger side of the aux harness.
                      Runs into the body here
                      Dives out and though the firewall near battery cable pass through
                      And dumps into the cockpit behind the electronics bulkhead
                      Getting there. Got a few inter-harness connectors to stab but that's mostly it for engine bay low power harnesses.
                      2002 E39 M5
                      • dvallis
                        • Oct 2015
                        • 1474
                        #881
                        More wiring. Adding the front suspension sensors.
                        Spent a ton of time under the car and in the engine bay figuring out where to mount these things. Displacement sensor is basically a rotary pot with precision wire reel and rotary tension spring. Was going to build it myself but repeatability, accuracy and temperature sensitivity are a big deal. These are normally $400 each but I scored a few on ebay for $50 each.
                        There are lots of things to interfere with the wire: tire, strut, sway bar ... etc. This location looks good for avoiding all that. I also wanted a secure way to mount the sensor. It's an odd shape.
                        Here's the mounting bracket
                        Sensor test fit
                        We're close to the turbo on passenger side so I decided to fab a heat shield
                        Final fit with the sensor wire. Looking good. Will do the driver side next time.
                        2002 E39 M5
                        • dvallis
                          • Oct 2015
                          • 1474
                          #882
                          Das Beast update. Haven't been posting a lot of the intermediate wiring work. It's repetitive. Big milestone today though. The engine bay low power wiring is pretty much done. Looks confusing without the schematic but its all there.
                          Wiring harness installed in the bulkhead.
                          Engine harness coiled up out of the way for the time being
                          Tomorrow we start on the high current engine bay wiring. It evolved based on a lot of discussion. Big change was moving the kill switch to driver's side. It's not technically required, but a good idea. If something happens, corner workers come to the driver's window first and look around there for the kill switch.
                          Also downsized the high current runs to #2 wire based on this chart (and others). My absolute peak calculated load is 125A for starting, and 90A max steady state. #2 wire should guarantee a 3% max drop for our 15' run.
                          2002 E39 M5
                          • dvallis
                            • Oct 2015
                            • 1474
                            #883
                            Stood around the car with Rob this morning for a long time talking about the kill switch. I'll be running this car in SCCA, NASA, Targa Newfoundland, Vintage, DEs ... who knows what else. The kill switch rules are slightly different for everything. We went with a setup that will cover them all.
                            - Accessible by driver when belted into the seat (WRL)
                            - Accessible outside car through open window (SCCA, NASA, WRL)
                            - Accessible if car is turned over (SCCA, NASA)
                            - Must disconnect battery and alternator from all electrical systems (All)
                            - Fire system remains energized (All)
                            Based on all this, we decided to mount it on the dash, left side, 6" inside the window. Will have a kill switch decal on the dash and on the door sill.
                            Wiring evolved a bit more as shown. It's nicely optimal setup in terms of wire runs, connectors, switch placement etc.
                            I bought this hydraulic crimper on eBay ages ago, anticipating doing the high power wiring sometime soon. LoL. Irrational exuberance.
                            It makes AWESOME crimps. You could hang an F-150 from the lug. :devil:
                            runs
                            Used the ETM to figure out the starter terminals. Looking at the back side of the starter: 3:00 - battery, 6:00 - 12V start, 12:00 - unloader (not used)
                            We sheathed both wires in 1200F mesh, ran the starter wire in the bundle and hid the alternator wire in the frame. Starter wire left, alternator right. Finished product is pretty slick.
                            3 of 4 power runs ready for the kill switch. We have more #2 on the way.
                            2002 E39 M5
                            • ForcedFirebird
                              • Feb 2007
                              • 8300
                              #884
                              You will need a diode on the alternator wire if you send it through the double pole safety switch, or the alternators will fry from back feed while the engine slows down.
                              Your car is a different animal, but in a stock car, all the power is terminated at the factory battery tray terminal, so the alternator wiring is redundant IMO, and have never failed a race tech.
                              So, when we wire them at the shop, the large cable and small cable that are on a stock run go through the switch - in fact all the BMW's we've turned into race cars were able to be wired this way (almost as if BMW intended them to become race cars lol). The small wire is isolated all the way to the battery terminal (no chance of any back feeds) and power the main relay. If you switch those wires at the same time, then engine shuts down, power is fully terminated at the switch, the alternator exciter wire goes dead - therefore meeting all requirements with a very simple two wire system.
                              As I said, not much relates to your car, but may help others trying to figure out the switch.
                              john@m20guru.com
                              Links:
                              • kronus
                                • Apr 2008
                                • 13032
                                #885
                                ^^ I've tried to build foolproof 1-pole kill switches in e30 wiring setups but have never succeeded, probably due to alternator feedback. They would usually fail the cut test due to turning off too slowly.
                                I usually use the second, smaller gauge pole to interrupt the coil.
                                cars beep boop
