Das Beast: My E30 track / street build
  • dvallis
    • Oct 2015
    • 1474
    #1621
    Upon closer inspection #5 was cracked
    New set of forged pistons and rods on the way
    "And then we broke the car. Again." Mark Donohue, "The Unfair Advantage"
    1987 E30 3L Turbo Stroker Das Beast
    2002 E39 M5
    • dvallis
      • Oct 2015
      • 1474
      #1622
      We'll dry sump this M20 next rebuild. Just because. This time we're going with a trap door oil pan. I'll post plans when it's done for anyone to duplicate.
      Remove stock baffle
      Cut off the stock sump
      Fine finish so it sits flat
      CAD the sides and top
      Add baffles
      2002 E39 M5
      • Digitalwave
        is a poseur
        • 6299
        #1623
        That motor was pretty short lived!
        RISING EDGE
        • dvallis
          • Oct 2015
          • 1474
          #1624
          Oil starvation will do that
          2002 E39 M5
          • dvallis
            • Oct 2015
            • 1474
            #1625
            New custom catch can by Alexander Neumann in Indiana. Dual AN16 with enough venting. He does nice work.
            2002 E39 M5
            • dvallis
              • Oct 2015
              • 1474
              #1626
              New rods. Wife ironically says "Those look cost effective"
              2002 E39 M5
              • JehTehsus
                • Dec 2019
                • 269
                #1627
                I received somewhat similar comments when I installed my piston rings on the dining room table...
                • zwill23
                  • Jul 2015
                  • 615
                  #1628
                  Cost effective in that they'll help keep your engine in one piece
                  • dvallis
                    • Oct 2015
                    • 1474
                    #1629
                    Oil pan is coming along nicely
                    2002 E39 M5
                    • dvallis
                      • Oct 2015
                      • 1474
                      #1630
                      Baffles in progress
                      2002 E39 M5
                      • Digitalwave
                        is a poseur
                        • 6299
                        #1631
                        Originally posted by ForcedFirebird
                        Check the little locating tab on the rocker shafts isn't protruding too much out of the head. The VC has a little "bridge" there that holds the tab down. If that tab is crooked, or raised, then it interferes with the VC sealing. The cover needs very little torque on the nuts to seal. I rub a ~1/32" layer of goop on there too (Right Stuff).
                        Just had to shout out the homie ForcedFirebird for this insight. I pulled my VC on Friday before racing at Homestead and sure enough, my rocker shaft "key" was sitting above the head by a good 2-3mm. Since I didn't want to adjust the rocker shaft positions, I just ground the key down slightly until it sat flush with the head. New gasket with a light skim of Right Stuff on both sides, and the VC did not leak one bit all weekend!
                        RISING EDGE
                        • dvallis
                          • Oct 2015
                          • 1474
                          #1632
                          Nice. Will be sure to check that.
                          2002 E39 M5
                          • moatilliatta
                            • 6151
                            #1633
                            Id be cautious of rivets internally in the pan.
                            @Zakspeed_US
                            • dvallis
                              • Oct 2015
                              • 1474
                              #1634
                              No kidding. They're just temporary. Baffles will all be tig'd into a single unit and rivets drilled out.
                              2002 E39 M5
                              • dvallis
                                • Oct 2015
                                • 1474
                                #1635
                                Got the trap doors and baffles done. A bit more finish work and it goes to the welder this week.
                                This is looking in from the bottom btw.
                                2002 E39 M5
