Bad tps!?!? Need help rev
  • e30wavee
    • Jun 2012
    • 36
    So last week I was driving back home from work I got on the highway and ripped through 2 & 3rd gear to find out my gas pedal was stuck down, the car was reving out to the max I got off the first exit I saw. popped the hood and saw the throttle body was stuck open, I pushed it back turned on the car & the idle was back to normal but as soon as I touch on the gas the rpm got stuck around 1800 & 2k. I managed to get it home cleaned out the icv and cleaned up the inside of the throttle plate checked the throttle cable from the pedal to the throttle body itself, replaced the tps with a spare one I had left over but still the same, when you turn the throttle body manually everything is OK but as soon as you touch the pedal then it acts up very random and weird I would really appreciate the help!?!?
  • dnguyen1963
    • Nov 2011
    • 2648
    Clean everything up then disconnect the negative battery cable for about 10 min to reset the ECU.
    • digger
      • Nov 2005
      • 6031
      disconnect the throttle cable from the throttle body and try and move cable in the sheath, the cable is probably binding
      • packratbimmer
        • Dec 2009
        • 1331
        Iced up TB? It was like 10 below last week!
        • jeffnhiscars
          • Jun 2011
          • 6010
          TB coolant hoses still there ?
          Alice the Time Capsule
          • Kershaw
            • 11822
            I agree with digger, your throttle cable is probably binding. Try to lube every that moves with the pedal too.
            AWD > RWD
            • e30wavee
              • Jun 2012
              • 36
              Yupp digger got it spot on i appreciate the help everyone finally got my baby back on the road again
              • digger
                • Nov 2005
                • 6031
                its worse on RHD vehicle as the cable goes near exhaust and they put a tight 90* bend just after firewall so they bind over time. its not fun getting stuck at WOT 7000rpm on the street bouncing off limiter.
                • jeffnhiscars
                  • Jun 2011
                  • 6010
                  Don't RHD cars have the engines flipped end to end to reduce torque steer ?
                  • Kershaw
                    • 11822
                    No, they just flipped the whole country end to end to reduce torque steer. That's why it's called down under.
                    AWD > RWD
                    • jeffnhiscars
                      • Jun 2011
                      • 6010
                      Dohhhh !! I'm such an idiot.
                      Thanks for pointing out the obvious
