How the f do i get the fuel injector clips off!!!!!!!
  • tjh1127
    • Feb 2012
    • 57
    I'm gonna flip out. I hate this shit. I don't want to take off the intake because that sucks even worse but I could only get off 2 of the clips but I just cannot get the others off the damn injectors to pull the rail. What. Do. I. Do. There is not a single solid wrote up on this anywhere.
  • reelizmpro
    • 9553
    with very small flathead screwdrivers?
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • tjh1127
      • Feb 2012
      • 57
      I hate this job more than Donald trump. All clips are off and I am literally just put all of y muscle into trying to pull the rail/injectors and they just don't buds.
      • BaltimoreBimmer
        • Apr 2016
        • 307
        better pull harder until it breaks! But in all seriousness. I decided not to mess with mine just yet because of the same issue
        • tjh1127
          • Feb 2012
          • 57
          • E30DriftMissile
            • Aug 2012
            • 301
            Holy shit [emoji23] so what did the trick?
            • tjh1127
              • Feb 2012
              • 57
              Cursing and pulling on it.
              • tjh1127
                • Feb 2012
                • 57
                Actually what I did was grabbed my biggest ratchet and longest extension and used it as a long lever and it popped right off. Turns out you don't need to take the clips off just to pop the fuckers from the sockets I was losing my mind
                • Steve Corbett
                  • Jul 2012
                  • 449
                  Make sure you have all the pintle caps. Sometimes one or two stay in the manifold.
                  Steve Corbett
                  1983 528E Scrapped
                  1983 528E Sold
                  1984 745I
                  1984 325E - Sold
                  1989 325I Bronzit-Sold
                  1989 325I Zinno
                  1988 635CSI
                  • tjh1127
                    • Feb 2012
                    • 57
                    Idk I fucked something up the fuel rail is leaking fuel all over today I give up im just taking it in
                    • jeffnhiscars
                      • Jun 2011
                      • 6011
                      Those are the nastiest injectors Ive ever seen. I'm guessing it ran like shit if it even ran.
                      I suspect your combustion chambers look the same. I'd do compression and leak down tests, a whole bunch of maintenance and hope i don't need to pull the head.
                      Alice the Time Capsule
                      • tjh1127
                        • Feb 2012
                        • 57
                        The head was just pulled by the last owner and a valve job done when the timing belt went. It ran fine just idled rough when cold
                        • jeffnhiscars
                          • Jun 2011
                          • 6011
                          if your combustion chambers look remotely,like those injectors you won't have a choice. The hot spots that can result from that kind of build up can cause catastrophic damage including burning a hole in a piston...notwithstanding that it will never run right.
                          • E30 Wagen
                            • Jul 2005
                            • 3434
                            Couldn't you just run some injector cleaner and some seafoam through the engine first, hit the freeway at 4000rpm for a few miles to try and burn away any build up? I've also heard of mixing a quart of atf in a full tank of gas can help clean out the injectors since atf has so much detergent.
                            My Feedback
                            • tjh1127
                              • Feb 2012
                              • 57
                              Two of the injectors are leaking at the rail. I've taken it apart twice and reassembled it and they are still fucking leaking. Wtf!?
