2.85 (2.9) Stroker with S50 Crank - it lives!
  • ForcedFirebird
    • Feb 2007
    • 8300
    #46
    Originally posted by zaq123
    Looking forward to the progress. To make this post useful.... when you will be doing your mockup and will need to install/remove the belt gear on the crank....pull the woodruff key and don't put it back until final assembly. It should save you from using a puller and makes the mockup easier.
    If everything is clean, you shouldn't need a puller. Usually a little rust, grime, or galling for the key is what's holding them on (or all three hehe).
    john@m20guru.com
    Links:
    • sert57
      • May 2014
      • 170
      #47
      Thanks for the tip!
      Got the final "final torques" done on the bottom end. this should be the last time I say that haha. I made sure to check clearances again, take a fine file to the areas I ground to remove the burs, and use lots of assembly lube.
      I then was able to disassemble the head completely, and I ordered a bimmerheads 272 billet cam and HD rockers. For a mild street stroker the 272 seemed to be the best cam. I think a 288 would have been too much for what I want. Next step will be getting the headwork done and checking Piston to Valve clearance, and getting the correct head gasket thickness.
      Still progressing slowly but surely.
      • digger
        • Nov 2005
        • 6216
        #48
        without ITB it makes sense to go mild with the cam, you cant push water uphill
        • zaq123
          • Jul 2016
          • 1574
          #49
          the assembly is pretty snug, especially with 2 keys in there. I'm going with 276 cam for my 2.9L. I know I'd want ITBs once she is up and running.
          • sert57
            • May 2014
            • 170
            #50
            Got the head back from the machine shop this week ( along with a few other goodies in the mail) and have mocked the engine up with the oem + .3mm HG
            I mocked it up with a VR + .3mm HG. The first time I measured P2V with clay the HG and head bolts were unused and I torqued them to spec.
            P2V seems pretty good, all measurements were above 0.07" using the clay method. I will try the dial indicator method next to verify this.
            I then reused the already torqued bolts and the already compressed HG and torqued the head down to spec again ( 22 ft-lb + 90 deg. + 90 deg.)
            I measured Piston to head clearance with 0.05" electrical saulder as well, and i measured the smallest clearance to me 0.02", with most of them between 0.025" and 0.03" . Yikes. Would re-torquing the head gasket have that much of an impact on the clearances?
            I also timed the cam. with the setup I am running it should be + 0.3 mm taller, so i would expect the cam to be about .6 degrees off. When I measured cam timing with a degree wheel I found I had to advance the cam about 1 degree to get it to spec. This is more than I estimated but it is still reasonable.
            • digger
              • Nov 2005
              • 6216
              #51
              sounds a bit too tight, was the head warped and machined without being straightened first? this can lead to uneven machining
              • sert57
                • May 2014
                • 170
                #52
                When i bought the engine it was from a 99k automatic, the PO had it torn down too do a turbo build on the stock rotating assembly. I know he had the head skimmed flat again, but i don't know how much. I measured the depth from the machined surface to the cat surface where the numbers are near cylinder 1 to be about 0.025"
                It's weird the me that p2v was still reasonable with that setup though.
                At this point it seems a .12" MLS is my best bet, hopefully raising the quench height by 0.04" ( to a minimum of 0.06) from the 2.05 HG.
                • digger
                  • Nov 2005
                  • 6216
                  #53
                  IMO you want 0.040-0.050" quench, this is the consensus of many professionals in the industry, some advocate even smaller but none really advocate much larger than this for a NA engine.
                  since you have variability you'd probably want the smallest to be about 0.035" as a minimum so that needs 0.015" thicker (0.098" ????). the max will be 0.065" which is getting too large but it is what it is....
                  • Dagamus(NM)
                    • 621
                    #54
                    I think this is exactly what water pumps do :p
                    Very curious to see where this ends up.
                    Gun control means using both hands
                    Sex, Drugs, Rock 'n roll. Pick two.
                    • digger
                      • Nov 2005
                      • 6216
                      #55
                      in this case it would be called a snail, but that doesnt count
                      • sert57
                        • May 2014
                        • 170
                        #56
                        Just got the 0.098" MLS gasket. torqued at 20 ft-lbs The Piston - head quench is about 0.047 - 0.050" measured via solder through the spark plug hole, seems right on the money to me ( only checked cylinder 1, I expect the highest gap to be about 0.056"
                        Cr is about 9.7:1
                        I'm onto final assembly and getting her in the car. exciting stuff. Hoping to have her running in a few weeks.
                        cam is times, valves adjusted, and i installed an I.E. oil pan baffle.
                        paring this with #19 bosch type 3 injectors w/ EV1 connectors ( i believe these are the mustang ones)
                        Running a custom sssquid chip for now, once I have more money i will probably go standalone MS2 PNP.
                        • digger
                          • Nov 2005
                          • 6216
                          #57
                          stock cam and head? should be a torquey SOB
                          • sert57
                            • May 2014
                            • 170
                            #58
                            272 bimmerheads cam, hd rockers. Should help some with peak power without loosing much low end torque. Ie longtubes will also be included
                            • sert57
                              • May 2014
                              • 170
                              #59
                              It lives
                              • digger
                                • Nov 2005
                                • 6216
                                #60
                                gonna stick with motronic?
