Help! Intermittent dying, CEL comes on all power loss.
  • driftxsequence
    • Apr 2015
    • 203
    So today was our longest trip ever since purchasing the car. A 2 hour drive each way. About 10 minutes from our destination the CEL would come on and the RPM gauge would drop like the key was turned off. Speedometer and everything else operated normally.
    When the CEL came on and rpm gauge died there was total power loss like someone turned the key off, then turned it back on and you resumed driving as you were. This creates some nasty bucking and happens 3-5 times for about 20 seconds and then it will drive fine for a few minutes.
    Any ideas or input would be great....i dont want to pay for a 2 hour tow home. Haha
    Car is a 1989 325ix
    325IX Build Thread
    RX7 Build Thread
  • peterman
    • Feb 2015
    • 173
    Rpm is based off yhe coil i think so that means no spark. Could be your crank positioning sensor, but i think that cuts fuel, not spark. Try the stomp test and write down the code. The cel will blink the code
    Sent from my SM-G935V using Tapatalk
    • driftxsequence
      • Apr 2015
      • 203
      Came back clear with no codes 1444
      I did tighten the positive terminal a LITTLE...hoping thats all it was.
      325IX Build Thread
      RX7 Build Thread
      • driftxsequence
        • Apr 2015
        • 203
        Positive terminal did not resolve the issue. Thinking it may be grounding. The water temp gauge was flopping around when the car would act up. Then when it was finethe gauge would hold steady. I know those sensors are very basic so it must be a ground issue. I will start with the shock tower and go from there.
        325IX Build Thread
        RX7 Build Thread
        • peterman
          • Feb 2015
          • 173
          Check the strap that connects to the oil pan... oil level sender area.
          Sent from my iPad using Tapatalk
          • TobyB
            • 5254
            was my thought, too.
            Also relays- just because at this point in their life,
            they're way beyond their expected life.
            Main and fuel pump...
            http://www.wedophones.com/BMWManualsLead.htm is a lifesaver here.
            Grounds on everything, too, of course.
            Also, this is less likely, but there is a big fusible link in the trunk, on the smaller
            of the 2 wires coming off the battery. They can get damaged, but usually that
            is a total power loss.
            t
            • redlightpete
              • Mar 2012
              • 264
              Check the circular connector below the intake manifold, C191 if I remember correctly. The injector harness and temp gauge sensor go through it.
                • 34839
                Mine did the exact same thing and it was confusing as heck to diagnose. I replaced the CPS, fuel pump, checked wiring, etc. Chased it for almost 2 years.
                It's most likely your main relay. If your relays are original - replace all 3 (Main, FP, O2 heater). The main relay turns on the DME, which is why the engine just "dies" (the car's power comes from a different wire, so it's not obvious). the tachometer drop is also because the DME is powered down.
                  If the DME was loosing power, the CEL would not come on. That tends to exonerate the main relay, fusible link, and DME ground. The tach signal is generated by the DME from timing data from the CPS. The tach going to zero and the CEL coming on usually means that the DME isn't seeing the CPS signal. The first thing to try is to replace the CPS with an OE or OEM part.
                  • driftxsequence
                    • Apr 2015
                    • 203
                    Sometimes it'll only do it for a moment like in the video, and others it'll be for a good 10 consecutive seconds....sorry its pretty poor but...its hard to capture.
                    325IX Build Thread
                    RX7 Build Thread
                    • Kershaw
                      • 11822
                      Does the car not lose power when that happens?
                      And yeah, try replacing the CPS. And maybe swap in a spare DME if you or a friend has one.
                      AWD > RWD
                      • supermansocks95
                        • Feb 2016
                        • 756
                        Same thing was happening to me a while back. I'll bet it's your main relay. I went through the fuel system and replaced the DME with one from my old car and still didn't work. The main relay finally did it. I honestly didn't think that was the problem, but it was...
                        At first, it was giving me the complete loss of power issue, then it started cutting fuel and leaning out. I replaced the fuel pump after the filter and checking everything else out and still no start. I then replaced that relay and BOOM. Haven't had an issue since.
                        88 325i Cabrio
                        04 Neon SRT-4
                        If R3v was a dude, it would pick up a tinder date naked, with a raging boner, drunk, in an e30 with a shitty interior, a missing sunroof panel, explaining how its a classic while staring at the tinder date's tits.
                          • 34839
                          even if the relays aren't the culprit (CPS can cause this as well), I would still replace them if they are original.
                          • supermansocks95
                            • Feb 2016
                            • 756
                            +1
                            Even though they're easy to replace, there's no need to tackle this issue again. Do it the right way sir. Don't be like some of us (me) and skip preventative maintenance. Lost an output flange and almost lost a driveshaft that way
                            88 325i Cabrio
                            04 Neon SRT-4
                            • TobyB
                              • 5254
                              This fooled me before, too- mine would 'blink'- the relay would interrupt DME power
                              for just long enough to reset it, and then it'd go through the startup diagnostic,
                              which illuminates the CEL.
                              fwiw.
                              t
