Schrick 284/272 timing
  • redlightpete
    • Mar 2012
    • 266
    I just installed a Schrick 284/272 and set it to what I think is supposed to be the TDC center position based on the German catalog. The #1 intake valve is open 2.2 mm and the #1 exhaust is open 1.7 mm (as closely as I could measure). In this position ,the stock cam gear is retarded approximately 4.5 degrees. Is this typical? Did Dr. Schrick just put the dowel pin hole in the wrong position? Am I doing something wrong?
    I was really hoping not to have to spend another couple hundred dollars for an adjustable cam sprocket. Arghh!
  • digger
    • Nov 2005
    • 6219
    its not uncommon for cams if installed in stock position for them to be actually advanced several degrees, i plotted out a 288 and was that way to. so do not worry as long as the PtoV clearances are all good (inlet side gets better clearance when retarding, exhaust gets worse). you can run it in several positions to see what the engine runs best at anyway.
    • redlightpete
      • Mar 2012
      • 266
      So what angle did you end up running your 288? And was that the angle measured at the cam sprocket or the crank? Thanks
      • digger
        • Nov 2005
        • 6219
        I didn't run it I just measured it. I'd run the 288 advanced slighty though, but not a 284/272 I've seen some guys do testing on this forum and advance didn't work well for 284/272 it dies in the top end will depend on specs if engine though.
        • redlightpete
          • Mar 2012
          • 266
          Perhaps that explains why a lot of strokers with the 284/272 flatten out at 5k. People might be accidentally running them in this default advanced position.
          Guess I'll go ahead and buy the adjustable gear. It's still frustrating to buy a 'premium' cam and then have to buy a $200 cam gear to get it to the recommended angle for the intended application.
          • digger
            • Nov 2005
            • 6219
            for a stroker a 284/272 is relatively small duration and lift. a few degrees retard on a 3.1L was best overall according to Tinkerputzer. Nando did tests on a 2.8 but dont remember the conclusions.
            • dvallis
              • Oct 2015
              • 1474
              Digger, what's the max you'd recommend advance or retard on a 284/272 ?
              "And then we broke the car. Again." Mark Donohue, "The Unfair Advantage"
              1987 E30 3L Turbo Stroker Das Beast
              2002 E39 M5
              • digger
                • Nov 2005
                • 6219
                i usually ask the engine, run it straight up and head to the dyno, advance/retard it a bit and see what happens.
                whenever i've done adjustments ive favored advanced about 4 degrees or more but thats relative to how it went in and if the cam is ground exactly as it says on paper. if it went in retarded by 4 degrees and you advance it by 4 degrees its actually straight up. the best position will depend on the engine specs but its hard to simulate thats why testing is best
                you just need to know the limits of how far you can move things before clearances get too tight before you start messing around too much.
                • redlightpete
                  • Mar 2012
                  • 266
                  Thanks for that reference to Tinkerputzer. I looked back through his cam angle comparison and your follow-up question. Seems quite possible that the 0 degree reference he was using was actually the advanced position the cam would be in if you installed it with the stock gear. If that was the case, the cam may have been at Schrick's recommended position during the '4 degrees retarded' test.
                    • 34847
                    advanced on the 284/272 killed low end torque *and* power. I think I retarded mine a few degrees but I can't remember exactly what I set it to.
                    IMO, an adjustable cam gear is money well spent.
                    • zaq123
                      • Jul 2016
                      • 1579
                      old post and all ....So is the consensus that Schrick 284 is advanced 4 degrees from their spec if installed with stock M20 cam gear? Basically, one needs to retard adj. sprocket 4 degrees to set it where Schrick wants it?
                      I'm gonna be playing with it on dyno... soon hopefully and want Schrick spec'd position to be my starting point.
                      • digger
                        • Nov 2005
                        • 6219
                        i happened to measure it and it is like 6 degrees advanced
                        • zaq123
                          • Jul 2016
                          • 1579
                          you mean it 6 degrees adv. if set with stock cam gear at TDC marks? So basically adjustable cam gear needs to be set at 6 degrees retarded so it's at Schrick spec position ? Just making sure I understand it right
                          • digger
                            • Nov 2005
                            • 6219
                            yes, when the stock cam gear mark is aligned to the head mark the cam is actually advanced, so by default the retarded position is likely to perform better. Note that both Nando and Tinkerputzer found that retarded in the order of 4 degrees or so was optimum. This would need to be verified on a case by case basis as i have heard of them being 180 degrees out to
                            • zaq123
                              • Jul 2016
                              • 1579
                              ok that makes sense. 4-6 degrees is hard to see without measuring but 180 haha...cyl1 cam lobes pointing up or down is kinda hard to miss. Can't believe they actually pass Schrick faculty quality control like that.
