Metric Mechanic 2900 Sport
  • digger
    • Nov 2005
    • 6162
    #46
    it delaminated, would probably cause reduction in pressure. how does the pump look? and the relief valve you want to make sure nothing else is the cause
    • jneumss
      • Mar 2016
      • 42
      #47
      Not sure on the oil pump yet. I brought it in to a local shop who services lots of e30's and he was going to inspect it for me - I could have done it myself, but I didn't want to take the chance of missing something due to being unfamiliar with it.
      The head and the block are at the machine shop - the machinist was a little nervous about installing new intermediate shaft bearings and I am not sure that he has started yet. The bearings are really hard, which surprised me, I thought they would be closer to a regular cam bearing or something, and they came in ~0.020" undersized to the intermediate shaft.
      I ordered a Bimmerheads 274 regrind, IE HD rockers, and everything else needed to get the head reassembled, so I can't wait to get that back.
      I haven't ordered any of the parts for the bottom end yet. It had standard size coated rod bearings and uncoated main bearings, so I was just planning on replacing with the same thing. I have been researching piston rings. I am leaning towards ordering a set of rings from MM, but open to any recommendations for other moly 86mm rings.
      • digger
        • Nov 2005
        • 6162
        #48
        because they need to be bored and honed in situ the int bearings probably are a little harder? any machine shop should have equipment to install them
        standard KS bearings or similar are all you need for mains and rods. for the rings id just get another set of Moly rings for the MM wiseco pistons.
        • jneumss
          • Mar 2016
          • 42
          #49
          Yeah, that was pretty much it. I have confidence that he'll be able to get it done and I hope to get it back this week sometime.
          The oil pump is ruined as well, there was a fair amount of wear/scoring inside, so a new one is on order.
          Also, I took the cover off the DME and it turns out I have one that has a stock 2.5l chip that is soldered directly to the main board, so I may search for a different DME and put in a SSSquid Chip until I am ready to put together a MS unit.
          • jneumss
            • Mar 2016
            • 42
            #50
            So the machine shop called me today and said everything was done except the intermediate shaft bearings. They said they did not know how they could size and install them. I've called around to several shops in the area and no one seems to want to touch it. I'm not really sure what to do here, I've tried explaining the process to install these bearings and I definitely can't put the engine back together in this condition.
            Does anyone know of any places in the Denver area that has done these bearings before?
            My other option is that I could send my block down to a shop called Memphis Motor Werks in Memphis that can do the work.
            Sent from my HTC One M9 using Tapatalk
            • jneumss
              • Mar 2016
              • 42
              #51
              So I haven't gotten anywhere on getting these intermediate shaft bearings replaced. I'm looking for some opinions on another option, would it be possible to just have the intermediate shaft turned down to clear the new bearings?
              After a quick internet search I haven't found anyone who has done that. After talking to Jim from MM, I got the feeling that this could be a possibility. He also said in a pinch that he has carefully taken the bearings out of old ETA blocks and installed them into an i block with good success as well. Not sure what to do here, looking for any other recommendations or possible solutions so I can get this thing back on the road.
              • digger
                • Nov 2005
                • 6162
                #52
                send the block to MM get them to do it and they will send it back
                • jneumss
                  • Mar 2016
                  • 42
                  #53
                  It's been a long 6 months between buying a house and moving the iX / engine over to my new place in boxes, being busy at work, and finally figuring out my intermediate shaft bearings.
                  Since I couldn't find anyone who could machine and install new OEM intermediate shaft bearings, I had some custom bearings made using oil impregnated bronze and were made to mimic the OEM bearings. I haven't seen or heard of anyone doing this before, do I'm praying that they won't give me any issues.
                  With the new bearings installed, I painted the block, took delivery of my new rings, rod bearings, and main bearings and I reassembled the bottom end.
                  I also found a brand new iX oil pump and waited about 35 days to receive it from Germany.
                  After building up the bottom end, I switched focus to the head. I replaced the valve stem seals and installed the 274 Bimmerheads Cam, with IE heavy duty rockers/oversized eccentrics.
                  And finally, over the past two days I reassembled the engine and it's ultimately ready to be installed in the car.
                  After the new year, I will hopefully have the time to mate the front subframe, engine, trans, TC and install from the bottom up.
                  • berlow94
                    • Jan 2013
                    • 1063
                    #54
                    Gold!
                    The best one-stop shopping for German car parts and lifestyle: http://www.gutenparts.com/
                    • jeffnhiscars
                      • Jun 2011
                      • 6011
                      #55
                      That sure looks a whole lot better :)
                      Alice the Time Capsule
                      • zaq123
                        • Jul 2016
                        • 1545
                        #56
                        Interesting approach for bearings. Shop that made/installed bearings couldn't machine OEM ones or there is some other trick? Just wondering why it was easier to produce those custom ones vs machining OEM units. Final fitting process would be the same (machine to the diameter +.001-.0015" clearance ->press in->final verification and minor honing to maintain the clearance)...no?
                        Those cylinder bores look super shiny or it's just a pic? Hopefully your new rings will break-in well.
                        • ForcedFirebird
                          • Feb 2007
                          • 8300
                          #57
                          ^^correct. Making custom bearings and installing would be no different than installing OEM.
                          It's not a difficult task, really, just have to pay attention during the process.
                          john@m20guru.com
                          Links:
                          • jneumss
                            • Mar 2016
                            • 42
                            #58
                            I don't really think there is any advantage to making custom bearings for the intermediate shaft. It was an extremely annoying process trying to get this machinist to work on the OEM bearings. And, in the end, he refused to work on the OEM bearings because they are harder than your typical cam bearing and came from the factory undersized. He was more confident he could make bearings out of bearing stock that was a softer material so that's how it came about. I couldn't believe that I had such a hard time finding a shop to do the install, but literally no one in the Denver area would touch it. I really hope that they work out.
                            Also, the shiny cylinder walls are a combination of a film of oil and lighting in the pic, they definitely weren't that shiny after being honed.
                            • jneumss
                              • Mar 2016
                              • 42
                              #59
                              Ok, so I've had the car running and driving for about two months, but have only put about 700 miles on it so far.
                              I have an issue that I'm battling, I'm running an SSSquid Stage 2 tune and I'm experiencing a hesitation between off idle and 3k rpm. In addition, I have low vacuum at idle ~10inHg and a steady low and slightly rough idle ~650 rpm. Above 3k rpm, the engine runs smooth and pulls hard through 5500rpm.
                              I also failed Colorado emissions having slightly high NOx. I had an average of 4.6545 and the limit is 4.0000 grams per mile. So it's definitely running a little lean. CO and HC emissions are well below the limits.
                              Things I have done to troubleshoot:
                              - smoke tests (no vacuum leaks)
                              -compression test (all good)
                              -new O2 sensor
                              -stomp test (no codes)
                              -Bentley electrical tests (nothing out of tolerance)
                              -valve adjustment
                              The only thing I haven't done is check the timing to ensure I'm not off a tooth or so, but that's my next step. Has anyone else experienced this or have any other ideas of things I could try out?
                              I found one other thread that had described symptoms like this, but they did not post any resolution and had a completely stock engine. Any other suggestions?
                              Sent from my Pixel 2 using Tapatalk
                              • earthwormjim
                                • Jul 2014
                                • 434
                                #60
                                Perhaps the closed position on your throttle body needs to be adjusted? To idle, the engine needs the idle control valve to function, and a very small opening on the throttle body.
