  • rex
    • Nov 2013
    • 150
    Thanks
  • varg
    Florida Turbo Man
    • May 2014
    • 3439
    If you have a decently large compressor: http://www.harborfreight.com/3-8-eig...ill-67474.html
    IG @turbovarg
    '91 318is, M20 turbo
    • Kershaw
      • 11822
      Does the old bolt still thread in? Maybe RTV it in place?
      AWD > RWD
      • Matt-B
        The Waffler
        • 3856
        id drill and retap
        • rex
          • Nov 2013
          • 150
          An angle drill could work. Seems like it would still be pretty hard to drill straigh and square inside the engine bay
          • rex
            • Nov 2013
            • 150
            Most I can get it to go is about 1.5 threads worth. Turning past that pops it out. I thought about RTV but i dunno if it would hold up to the pressure since it's not even close to fully in there.
            • rex
              • Nov 2013
              • 150
              Originally posted by Matt-B
              id drill and retap
              I agree this is the eventual necessary solution, just wondering if I can do it properly without pulling the motor.
              • rex
                • Nov 2013
                • 150
                Another idea I had was to fill the hole using JB weld putty, thinking that I was going to have to re-drill the hole anyway later on. Bad idea?
                • Seawolf
                  • Feb 2015
                  • 270
                  You could try some copper wire, insert 6 strands of copper wire into the hole (this will be tricky with the plugs location) and wind the plug in without the sealing washer. The hole may just have enough thread to grip the soft copper.
                  If this holds well enough unscrew the plug, snip the copper wire ends with a pair of good side cutters fit the sealing washer, apply thread sealant to the plug and wrench it down.
                  You will be able to apply more heave than you think to this and it has worked well on a few stripped ally threads in the past where overdrilling wasn't an option. Use a medium gauge single strand wire.
                  • Old525i
                    • Oct 2015
                    • 32
                    Remove cat. Plenty of space will open up.
                    • Kershaw
                      • 11822
                      If you can't thread the bolt in, there is metal to tap. I'd try to retap it with an actual tap, not a thread restore. Then thread restore the bolt. Check to see if it goes in. Then Teflon tape the bolt and put it in.
                      Sent from my SGH-M919 using Tapatalk
                      AWD > RWD
                      • packratbimmer
                        • Dec 2009
                        • 1335
                        Drill and use expanding rubber plug. Make sure to flush metal shavings
                        • rex
                          • Nov 2013
                          • 150
                          I used an actual tap, or at least the only thing I know of as a tap, looked like this except it was the right size-pitch. It seemed to work fine.
                          The tap also pops back out when I go past a certain point, just like the bolt did
                          • rex
                            • Nov 2013
                            • 150
                            Some guys on the r3v Facebook group suggested an expanding rubber plug and I have ordered one (no local stores had em and I went everywhere looking lol) and will give it a shot.
                            • rex
                              • Nov 2013
                              • 150
                              Cool, great to hear
