Claying pistons for clearance
  • digger
    • Nov 2005
    • 6041
    I laser cut a gasket from 2mm aluminium sheet. It's just a fancy spacer, itvwont Marr the head not that i noticed the stock gasket did. I use it as reference to work out how thick of a mls ( not cheap) I need
      • 34839
      I don't think there's enough clamping force on the head bolts to "dent" the head around the compression ring.
      • e30davie
        • Apr 2016
        • 1788
        Yah ive never seen a "dents" from the rings on any head i've removed, bmw or otherwise.
        • zaq123
          • Jul 2016
          • 1443
          my m20 head had clearly visible and tangible marks in it from HG. Maybe I'm too ocd. I can see spacer not marring the head but OEM head gasket isn't all metal
          • digger
            • Nov 2005
            • 6041
            was it indention of just discoloration / deposits?
            • TobyB
              • 5220
              The only time I've seen a head deformed by the gasket is the
              2002 'cutting ring' gasket- it has a ridge in the head side that's
              designed to o- ring itself into the head material.
              And even that made a gouge not much over.005" deep.
              Other than that, a flat gasket just won't hurt the head surface...
              ...and I just use an old gasket, too. Snugged, but not torqued.
              t
              • zaq123
                • Jul 2016
                • 1443
                It possibly was a discoloration......the head was skimmed and for some reason I remember indentations around HG rings....Maybe it was the deck....the deck definitely had some electrolysis pitting/corrosion around the rings before it was resurfaced.
                I don't have old HG. So you guys recommend to torque new cheap HG all the way with old bolts to clay it properly?
                • digger
                  • Nov 2005
                  • 6041
                  no need to torque the hell out of it IMO but if you have an old set of bolts and cheap HG then go right ahead, i would use a VR gasket or similar of the same thickness. i usually order a VR topend gasket kit and an OE HG gasket (better quality) so there is a spare HG left over anyway
                  • zaq123
                    • Jul 2016
                    • 1443
                    quick update:
                    Pistons are 10:1 advertized. I got VR test gasket (+0.3 oversized) and used 2mm solder wire. My P dome to H clearances are in mm...
                    cyl1 - 1.33 cyl2-1.30 cyl3-1.26 cyl4-1.25 cyl5-1.19 cyl6-1.21
                    Mahle recommended clearance for steel rods 0.04" or 1.02mm. I'm using H beam forged 4340 rods
                    I already have STD size OEM gasket but it will reduce recommended clearance to 0.035" on cyl5 with my setup. I haven't checked P to V yet (waiting on the TB parts) but IE/Mahle pockets look deep (I will obviously verify the exact P to V clearance).
                    Putting P to V clearance aside at this moment.....would you guys recommend to run +0.3 heads gasket with or go with STD one? This build should be capable to run on pump premium gas.
                    • digger
                      • Nov 2005
                      • 6041
                      Standard, the better squish more than offsets the slight increase in CR
