A little spark plug inquiry
  • Mortification
    • Feb 2017
    • 42
    Wey I just removed some of my plugs and wanted your guys opinions. Also confused about the liquid substance I found on them. On to the pics...
    onrock/media/431218BB-DA57-4574-BD53-663E03A139F4.jpg.html][/URL]
  • Mortification
    • Feb 2017
    • 42
    Also just noticed part is #BPR7ES... which doesn't trace to a 325 at all ?
    • e30davie
      • Apr 2016
      • 1788
      is that lyquid oil or fuel?
      If that pool of liquid in your spark plug hold oil? if so your tappet cover gasket might be leakin.
      Hard to tell from those photos, but they do look a bit sooted up. does it run rich? hows your fuel economy?
      Do you know when they were last changed? If they are fairly new, give them a clean up and re-gap them. If you dont know just throw some new ones in.
      • UlrichFennec
        • Dec 2014
        • 1268
        You look like you're running rich. Was the liquid on the plugs oily or was it fuel?
        "Leafeon" '92 Lagunengrun 325i Vert (Daily Driver/Project)
        http://www.r3vlimited.com/board/showthread.php?t=366044
        The stickers make it go faster. :nice:
          • 34847
          BPR7ES are 2 heat ranges cooler than stock IIRC. There's not neccesarily anything wrong with them, but I would switch to a BPR5ES for a stock engine.
          Funny thing is when you search for these plugs, they are also used in lawn mowers. lol
          • YosemiteSam
            • Apr 2011
            • 1303
            I hope I'm wrong, but from those pictures that fluid looks kinda coolant-ey to me. If that's the case OP, that would not be a good sign.
            • flyboyx
              • 8371
              i think it looks like oil
              Gigitty Gigitty!!!!
                • 34847
                yeah if it was enough coolant to coat the plug, I think you would know by the huge clouds of smoke coming out of the engine.
                • Mortification
                  • Feb 2017
                  • 42
                  Well if it was coolant where would it be coming from? I'm not sure but it seems all the plugs have it. Maybe wd40? I didn't do this and I just got car not too long ago. Also car had a previous turbo setup and had a turbo chip... hence the plugs I'm guessing and the running rich part. I just switched the chip out. From my understanding these cars don't have spark plug seals like Hondas do. So it's definitely not coolant. The fluid was in too part of plug. Not inside... if it was coolant my guess would be that it'd be on then plug itself from combustion chamber? Correct me if I'm wrong.
                  • Mortification
                    • Feb 2017
                    • 42
                    Also ... FYI head gasket was just done by previous owner. Or so I was told but the head looks clean as hell to me so I believe it. Also the engine is a 2.7 with a is head from what I've been researching.
                      • 34847
                      he probably meant to go one heat range hotter - but NGK numbers work backwards. lower number is hotter, higher number is colder.
                      • Mortification
                        • Feb 2017
                        • 42
                        Well I have a old thread about me trying to find out what my car had. Apparently car was running a turbo setup. Hence the colder plug. Gonna switch back to stock today
                        • ForcedFirebird
                          • Feb 2007
                          • 8300
                          bpr7es is a popular turbo plug. PO probably just never went back to stock when selling the car.
                          john@m20guru.com
                          Links:
                          • Mortification
                            • Feb 2017
                            • 42
                            Also can anyone tell me anything about that pulse sensor that goes on the spark plug wire? I'm running a I/is head on a 2.7 block apparently and can't find details as to what that wire does or where it connects to. Any insight would be greatly appreciated. I'm completely new to this e30 stuff. Thanks
                            • Mortification
                              • Feb 2017
                              • 42
                              Heck I don't even have that sensor on any wire
