green or orange coolant??
  • cheffy30
    • Sep 2016
    • 1159
    gearheads...
    which coolant should you use? the green or orange??
    i have the m20 autoslug with 246k
    someone told me that i should be using orange...
    its had the premixed green shit in there for the life of the car so far...
    advice please...
    '90 325i sedan daily driven
    '85 325e coupe also a daily
  • flyboyx
    • 8371
    we are actually supposed to be using "blue"
    Gigitty Gigitty!!!!
    • E30335i
      • Feb 2014
      • 1035
      The orange is for the gm cars
      • dnguyen1963
        • Nov 2011
        • 2651
        As long as it is designed for aluminum engine, it is safe to use. The color is just a dye.
        • slammin.e28
          שמע ישראל
          • 12054
          Orange Dexcool stuff is shit.
          Stick with the green or blue. I prefer the look of the BMW blue stuff.
          • McGyver
            • 4634
            Pink, then tell people its an Audi/VW/Porsche
            • MrBurgundy
              R3V Degenerate
              • Mar 2012
              • 5563
              What's your favorite color?
              • jeffnhiscars
                • Jun 2011
                • 6011
                Avoid anything with phosphates..and yes, get the blue from the dealer for $20-25. It's a 2 years maintenance item so not worth cutting corners on
                Alice the Time Capsule
                • c0rbin9
                  • Dec 2015
                  • 609
                  Zerex G-05 is BMW equivalent for a little cheaper - find it at your local O'Reilly's. Phosphate free, low silicate, aluminum safe - high quality base stock. Best stuff you can find short of Pentosin/OEM.
                  EDIT: Did a little more research and if you want to get technical the actual BMW equivalent is the similar formulation G-48, not the G-05. G-48 is specifically recommended for BMWs and is the same formulation as what you buy at the dealership. The main difference between it and the G-05 is that the G-48 is nitrite free. Good luck finding it though.
                  1991 318is Brillantrot daily driver (slow restoration)
                  • jeffnhiscars
                    • Jun 2011
                    • 6011
                    But is it blue
                    • c0rbin9
                      • Dec 2015
                      • 609
                      It's more of a healthy golden color.
                      • e30davie
                        • Apr 2016
                        • 1788
                        Dunno what the situation is like in the US of A, but in Australia the genuine blue coolant from BMW is cheaper than the aftermarket stuff from parts shops (green or orange etc).
                        I don't think it matters too much what you use, as long as its for aluminium engines and I think the general consensus is don't mix colors together.
                        • Northern
                          I like cupcakes & sh!tboxes
                          • 5247
                          I've been unning the Zerex G-05 for a few years now.
                          I think I bought a few bottles at one point, then every subsequent time I've needed coolant, I'd already have 1 or more bottles around so I never actually switched to BMW coolant.
                          Originally posted by priapism
                          Originally posted by shameson
                          • 4tDX
                            • Jul 2014
                            • 509
                            Rainbows of coolant and engine oil, but blue brake fluid! ARE YOU OUT OF YOUR F**KING MIND?!?
                            • TobyB
                              • 5265
                              ...blue brake fluid is not DOT approved. Know why? It's blue....
                              hee. fucking. hee.
                              Coolant. Like oil, not too important what kind you use, as long as you change it every couple
                              of years. And don't mix the wrong colors....
                              t
