RTV Gasket Sealer on Intake Manifold Gaskets?
  • e30sh
    • Apr 2015
    • 618
    Mark the driveshaft / output shaft or tire and rotate. Should be ~ 3 3/4's or a little over 4 turns to determine your gear ratio.
    • jeffnhiscars
      • Jun 2011
      • 6011
      make sure you have the washers and spring in the right configuration on the bitch tube
      Alice the Time Capsule
      • redlightpete
        • Mar 2012
        • 265
        Regarding your 3.73, when I refreshed mine, the pinion bearings were completely worn out and loud. The other bearings were ok. Might want to at least inspect them while you’re in there.
        • zaq123
          • Jul 2016
          • 1560
          was it a pain to set gear lash after you replaced the bearing? I have my diff out right now. Replacing output seals but hesitating to mess with the input flange. Did it once on the truck diff and was a major PITA: shimming, crush sleeve, paint gears and check, disassemble...new shims, assemble paint......check
          • redlightpete
            • Mar 2012
            • 265
            I measured everything carefully, and the replacement bearings were the same thickness, so I didn’t end up changing any shims. I just set the preload with a new crush sleeve and checked it with paint.
            If you just disassemble the pinion to check the bearings, you’d only need to redo the crush sleeve and preload.
            • LowR3V'in
              • 4209
              my throttle body flange warped so i had to file it down flat again.
              Didn't try to polishing it out, just filed it flat and i used gasgacinch. very good sealant.
              normally i just copper spray every single paper gasket though. even the metal exhaust gaskets.
              head gasket. metal turbo gasket. even if ur engine is stock another level of 'just in case' is good.
              • Echo30V
                • Sep 2017
                • 301
                I know how to test for friction plate issues but how can I tell if I need to refresh pinion bearings etc. I'm buying a used 3.73 to install but want to refresh. How can I tell if pinion bearings, crush sleeve etc need to be replaced.
                • jeffnhiscars
                  • Jun 2011
                  • 6011
                  I'm still trying to figure out how one warps a throttle body
                  • LowR3V'in
                    • 4209
                    ^a different flange welded on it. got too hot.
                    • jeffnhiscars
                      • Jun 2011
                      • 6011
                      Ahh...well...that would do it :-)
                      • 15Michaeljoseph
                        • Aug 2013
                        • 1693
                        Oops, forgot that in my little summary hahah, copper spray on the head gasket makes for successful sealing!
                        Sent from my XT1064 using Tapatalk
                        (OO=[][]=OO) For Life
                        • Echo30V
                          • Sep 2017
                          • 301
                          So I picked up the 3.73 LSD Diff. Ordered all the seals and am still up in the air about replacing the friction plates. What do you guys suggest? Is there a good aftermarket friction plate brand instead of BMW?
                          • e30davie
                            • Apr 2016
                            • 1788
                            Id ring a few differential shops and see what they suggest. Might be a standard size etc.
