Changing Timing Belt Only / No WP
  • iso_hi
    • Dec 2014
    • 510
    So when I got my MTech Vert a month ago i noticed there was writing in the engine bay that hinted the water pump had been changed a couple thousand miles ago. No info on the timing belt. So I went to the shop and he confirmed only the pump was changed.
    My question: is it possible to change the timing belt without removing the coolant/hoses?
    I just flushed the coolant and thermostat a couple weeks ago and hate bleeding the system. I’ll do it if I have to.
    1987 325 Turbo
  • digger
    • Nov 2005
    • 6163
    pretty sure you have to as radiator needs to come out and covers are connected to the metal coolant tube etc etc.
    raise the front of the car it is a piece of piss to bleed. you dont need to drain all the coolant leave the block plug alone
    • iso_hi
      • Dec 2014
      • 510
      Ok that’s what I was thinking I was hoping someone had a secret method I haven’t heard of lol. Thanks!
      1987 325 Turbo
      • berlow94
        • Jan 2013
        • 1063
        Do yourself a favor and buy a pneumatic coolant bleed tool.
        The best one-stop shopping for German car parts and lifestyle: http://www.gutenparts.com/
        • jeffnhiscars
          • Jun 2011
          • 6011
          If the tstat doesn't have a bleed hole I drill one and have never EVER had any issue bleeding...but then I've never had a fan clutch refuse to come off so maybe I'm just lucky
          Alice the Time Capsule
          • SteveO
            • Jul 2015
            • 20
            Ive never ever had an issue with bleeding the coolant as well, but I have the bleed hole on the thermostat and drive to a steep hill once its warmed up to let out any air if there is any.
              • 34844
              Huh? I've never once removed the radiator to do the timing belt.
              However, you definitely have to remove all the hoses. Never had problems bleeding either, but sometimes things are just a bitch...
              • digger
                • Nov 2005
                • 6163
                I value my knuckles lol, given the coolant is drained and hoses out it takes all of 2mins makes it so much easier.
                  • 34844
                  depends - it's not that easy with an automatic, and many people have fans attached to it. I never found it to be an issue, but I do agree having the extra room can be nice (having just fought through a water pump replacement on my 330i, where getting the pump physically in and out of it's mounting point is a puzzle all on it's own).
                  • downforce22
                    • Aug 2009
                    • 3192
                    Not a problem to change the Timing belt only. I've done with radiator in and with radiator out. Its fine both ways but with the radiator out is much easier and as mentioned easier on the knuckles. If you leave the hoses connected and just disconnect them from the water pump/ thermostat you can pull the radiator out as one unit.
                    • ForcedFirebird
                      • Feb 2007
                      • 8300
                      People tend to over complicate things. The m20 expansion tank is made to be easily removed and lifted well above the engine so release all the bubbles. No need for special tools. I found a funnel that fits exactly in the cap opening so even removing it is not completely necessary. The bleeder doesn't even need to be opened, but does speed things up a bit. If the cap is higher than all the hoses, then all is well, but if you are parked on a slope, or even have a cheap upper hose that's too high, that's when the air gets trapped.
                      As Jeff said, a small bleeder hole at the top of the thermostat also helps.
                      The radiator removal does speed up the whole timing belt/pump job - in fact I remove the hood every time too. As digger said, those few minutes at the start/end of the job really speeds up the middle lol.
                      And yes, the belt and/or pump can be changed independently, but be cautious when installing a pump only. If you don't disturb the belt and change the pump, it's very easy for it to catch the edge of the tensioner during install and not seal completely (but your case is opposite OP).
                      john@m20guru.com
                      Links:
