284 cam too much for a 2.5L M20?
  • apostate
    • Feb 2012
    • 148
    #46
    God, I wish you didn't save the Queen or killed Columbus's embryo.
    • ForcedFirebird
      • Feb 2007
      • 8300
      #47
      Originally posted by 2mAn
      John you need to start a Dyno thread for the M20 to compliment Daves 24v and more dyno thread....
      Perhaps. Generally I have a tab open to a couple forums so when shop programs are loading, browse and chat in the meantime. Many of the builds here have owners that don't care to advertise what they have. Our YouTube videos are taken by owners, or at owners' request.
      john@m20guru.com
      Links:
      • 2mAn
        Señior Mod
        • 20939
        #48
        Leave them anonymous! We need dyno sheets... well, everyone but one.
        Simon
        Current Cars:
        -1966 Blue Boat
        -1969 Red VW
        -1986 White BMW
        -2006 Green Thing
        Make R3V Great Again -2020
        • ThatOneEuroE30
          • Dec 2013
          • 8626
          #49
          You do realize there is no such thing as “real HP” either its a mathematical number based off torque. Its very clear your just blowing smoke. You will never know how much power your making off of just making a pass unless you are using a virtual dyno with a lap tap riding shot gun. Or a the good ol ass dyno
          1991 318i 4dr slick top
          Mtech 2 turbo restoration
          • apostate
            • Feb 2012
            • 148
            #50
            • digger
              • Nov 2005
              • 6172
              #51
              Originally posted by ForcedFirebird
              Not true in the least. Look at the Pure Stock Class in NHRA. Any cam/springs are allowed without machining the pockets, stock head and rotating assembly, weight is based on displacement, but torque converters are open. So, you put a car with a 4k stall in it on the dyno, make a run and your numbers will be all screwey, but let me tell you 1/4mi runs calculated to HP based on weight and trap speeds is a joke. I have seen 10" tire 3800cc powered Firebird run a 12 flat in pure stock. Based on the "1/4mi dyno", this should be a ~350whp car at 2700lb, but he is about 100whp short of that - yet nails a 1.3 60' with one wheel up. The 1320 is make or break in the short times.
              Any flat tapped push rod is also sliding, and limits the domestic ramp rates as well as the friction surfaces requiring zinc (much like the m20).
              Only trapspeed and weight can correlate decent to hp but it's average hp (over the range of rpm used during the run ). Still it won't give a curve so how much meaning do you place on it if it's not a drag car ?
              Yeah bad choice of words, I mean sweeping motion, even m50 slides
              • ForcedFirebird
                • Feb 2007
                • 8300
                #52
                True. Didn't intend to imply it was meaningless, but rather calculated HP numbers are skewed when using drag racing. The numbers won't correlate to what the engine actually makes if taken at the wheels and/or crank. Just like a dyno, it can show improvements. Guess I'm getting hung up on chasing one and two HP here and there to stay within a rule-set, the dyno is perfect for this - as well as quickly nailing MBT.
                john@m20guru.com
                Links:
                • digger
                  • Nov 2005
                  • 6172
                  #53
                  catcams have totally revamped their m20 cams recently
                  • 2mAn
                    Señior Mod
                    • 20939
                    #54
                    Clearly the answer here is ROB
                    Simon
                    Current Cars:
                    -1966 Blue Boat
                    -1969 Red VW
                    -1986 White BMW
                    -2006 Green Thing
