Bolt on adjustable FPR
  • digger
    • Nov 2005
    • 6181
    I agree pull the lines off when it reads zero. If a decent amount comes out then it will pressurise really fast. If not much comes out then I think there is an issue.
    • Digitalwave
      is a poseur
      • 6299
      Yes, the lines and rail stay filled. I pulled the rail and injectors last night and it was still completely full of fuel (it holds quite a bit!). Fuel pressurizes to 3 bar with one key turn (pumps prime for 2 seconds I believe). Sounds normal then.
      RISING EDGE
      • parkerbink
        • Jun 2004
        • 10138
        I have this one, less than 200 miles on it.
        I'd do 120 shipped.
        • Digitalwave
          is a poseur
          • 6299
          That one doesn't bolt on to the stock fuel rail, it has to be remotely mounted.
          RISING EDGE
          • parkerbink
            • Jun 2004
            • 10138
            It replaces the oem directly into the rail.
            • Digitalwave
              is a poseur
              • 6299
              Note: These are a remote mounting type due to clearance issues inside the engine bay. We include a fuel rail adapter not shown in the product photo.
              I'm looking for one that directly replaces the stock FPR, without being remotely mounted. Like this one: https://www.lindseyracing.com/LR/Porsche/944-4037.html
              RISING EDGE
              • parkerbink
                • Jun 2004
                • 10138
                Understood.
                • ForcedFirebird
                  • Feb 2007
                  • 8300
                  For giggles, try a fuel volume test at the stock pump outlet. Should be about 15sec to fill a 1ltr container. Anything less and your pump is bleeding back.
                  john@m20guru.com
                  Links:
                  • AndrewBird
                    The Mad Scientist
                    • 11898
                    I had a similar issue with my E34. REplaced everything you did and still would get pressure loss after sitting, causing a long start. I ended up putting a one-way valve in the fuel supply line right at the pump and it fixed the problem. I used this one with the appropriate barbs on each end:
                    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
                    • digger
                      • Nov 2005
                      • 6181
                      There is also an OE part that works from one of the other models.
                      If you still get issues after installing a check valve then atleast it helps you isolate the pump as an issue and you can focus on downstream causes
                      • Andre3127
                        • Dec 2017
                        • 291
                        By any chance, can you smell fuel in the engine bay after an hour? Just for the sake of sharing, I used a light wipe of silicone grease on my injector O-rings where they connect to the fuel rail to help them seal. If your injectors are leaking from there it might not hurt to try that.
                        Sent from my XT1053 using Tapatalk
                        Budget E30 Parts - Used and Reconditioned parts for your BMW
                        • Digitalwave
                          is a poseur
                          • 6299
                          I don't have any smell of fuel anywhere, ever.
                          I had my injectors tested over the weekend. They took them up to 100psi and they didn't leak a drop. So we can rule that out.
                          RISING EDGE
