325i M20 alternator
  • digger
    • Nov 2005
    • 6160
    325i M20 alternator
    Does anyone know a good source for an alternator?
    Bosch have a 90A p/n AL49X as a re manufactured unit but based on the pictures it appears that some OE one are isolated with rubber bushes and this isnt? can anyone confirm?
  • Kershaw
    • 11822
    I have noticed that some have bushings and some don't. I don't know which models came with which, it seemed random to me.
    AWD > RWD
    • digger
      • Nov 2005
      • 6160
      It seems that it may be the 80A or ones from e30 m3 with bushings.
      • E30SPDFRK
        • 5709
        M10, S14, and M20 up to 11/85 have rubber mounted 80A alternators. The solid mounted one is 90/95A and a direct bolt on replacement.
        Byron
        Leichtbau
        • digger
          • Nov 2005
          • 6160
          thanks, i started to come to that conclusion myself after enough googling of part numbers.
          • zaq123
            • Jul 2016
            • 1542
            don't get one with bushings....it's a common mod to install solid alum. bushings to replace stock as they fail. No bushing...no failures....BMW finally figured it out later on...there is no need for them in the alt.
            • digger
              • Nov 2005
              • 6160
              yeah the bushed are the 80A variants buylooks of it. bought a AL49x solid connection. was more concerned about the OE being bushed and the el cheapo solid.
              • digger
                • Nov 2005
                • 6160
                new pulley has no keyway. anyone elase encountered the issue?
                https://www.ecstuning.com/b-genuine-...m/12311288238/
                surely im not upposed to removed the key and run alternator on friction grip?
                • zaq123
                  • Jul 2016
                  • 1542
                  I remember reading about it. Bosch had a few different pulleys, 2 piece, keyed and non-keyed. The consensus is it will be fine without a key. Install/torque the pulley correctly and belt will slip way before the pulley will.
                  Click image for larger version  Name:	s-l300.jpg Views:	0 Size:	14.5 KB ID:	9868561
                  Click image for larger version  Name:	13833417454_44ac702c47_b.jpg Views:	0 Size:	69.5 KB ID:	9868560
                  • digger
                    • Nov 2005
                    • 6160
                    I'll probably just reuse the pulley and if the original in non keyed I'll just replicate that.
                    • ForcedFirebird
                      • Feb 2007
                      • 8300
                      The bushing and non-bushed alternators are almost identical - save the front cover. If you have a used non-bushed alternator and a new bushed unit, just remove the bolts and swap covers.
                      Honestly, it's been a bit since I have seen a bushed reman alternator - almost a decade to be less than exact.
                      john@m20guru.com
                      Links:
