Denso Iridium spark plug gap .8 mm?
  • dirtywhiteboy
    • 53
    replacing spark plugs in my 87 325is w stock motor, checked to see if the Denso Iridium's are pre-gapped (apparently not) and found them calling for a .8mm gap in the M20. Has anyone run them that wide? Is it correct? Taking it on a 500 mile tmoro, not wanting to have any issues on the way... http://www.globaldenso.com/cgi-bin/g...ename=4w-7.txt
  • Massive Lee
    • Sep 2006
    • 6785
    Our old cars were designed to use spark plugs that would work on a wide range of combustion mixtures. Sometimes on the rich side. Sometimes on the lean side. Good old copper spark plugs work well in this environment. Iridium spark plugs are designed for much newer motors that work in a very narrow mixture range. Therefore, I am not persuaded these newer technology spark plugs are the best for our old cars. Bring a set of copper spark plugs just in case... ;-)
    massivebrakes.com
    • digger
      • Nov 2005
      • 6198
      either get the proper NGK ZR5GRA (whatver it is) or run the iridium as is they arent supposed to be adjusted and shold work fine on a healthy ignition setup.
      • usualdeviant
        • Mar 2012
        • 122
        I tried swapping plugs for Iridium but what I found was they do not have removable caps so our wires do not plug in...
        • packratbimmer
          • Dec 2009
          • 1335
          I've had them in my car for five years and they have been great. The ones I have had the tops that screw off. I am running 19 lb. 4-pintle Ford injectors and a SSSquid chip tuned for them with a Denso oxygen sensor. Smoothest M20B25 I have had and great in-town driveability. Not sure if they would work as well with a stock tune. My advice for stock chip users is to use 715 stock injectors and copper plugs.
          • dnguyen1963
            • Nov 2011
            • 2651
            NGK ZR5GRA is still widely available. Why look for something else?
            • Northern
              I like cupcakes & sh!tboxes
              • 5284
              With all the complaints of the M20's running shitty on iridium plugs, I never even considered it. Bosch or NGK coppers for me.
              It's not like you have to remove anything to get at the plugs, so what benefit will you see out of the extra life of iridiums anyway.
              Originally posted by priapism
              Originally posted by shameson
              • ForcedFirebird
                • Feb 2007
                • 8300
                I agree with the others. The system was designed to work with copper plugs, and we run them in long endurance races with no issues.
                john@m20guru.com
                Links:
